Belly Dump Loading and Tarping Question
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by OldRed98, Mar 21, 2021.
  1. OldRed98
    OldRed98 Medium Load Member
    308
    251
    Apr 18, 2017
    Colorado
    I'm installing an electric flip tarp on my belly dump trailer. With all the construction here in Colorado, I'm hoping to find some work with it.
    I have an old Fruehauf double hopper belly.
    I see a lot of belly dump trailers have wooden forms at the top of the hoppers. My trailer doesn't. I have loaded 25 tons of crushed asphalt without overflowing. But as I'm adding a new tarp system, now is a good time to add wooden forms at the top.
    Do any of you more experienced dump trailer operators think there is a benefit of adding forms at the top of the hopper?
    I included a couple of photos so you can see what my trailer looks like.
    I think a lot of trailers where built to have the forms added at the top. Mine wasn't. The top edge of my trailer is kind of tappered
    Thank you
    Cat sdp Thanks this.
  3. bonder45
    bonder45 Road Train Member
    1,803
    5,445
    Oct 2, 2011
    Williston, ND
    Depending on what you’re loading it takes up more space.
    From what I remember they can overload 1” fill and have it falling out of the top ( with wood ) and you’re still within weight limits.
    OldRed98 Thanks this.
  4. OldRed98
    308
    251
    Apr 18, 2017
    Colorado
    I expect to haul a lot of dirt and aggregate. Hoping to find work with some of the gravel pits around here. Only problem is that there are some big fleets here that have day cab trucks with brand new belly dumps which I bet are lightweight.
    Its been a while since I scaled loads in this trailer but I know I was about 85,000/86,000 lbs with crushed asphault and still had some room. That was about 50,000/51,000 lbs of material. I think I weight 35,000 empty.
  5. REO6205
    REO6205 Road Train Member
    13,172
    60,482
    Feb 15, 2014
    California.
    Those boards take a lot of punishment if you have sloppy loader operators but it's easier to repair or change out a board than to do metal work on your trailer.
  6. OldRed98
    308
    251
    Apr 18, 2017
    Colorado
    Thanks for your input everyone!
    I've never done belly dump work for hire. I bought this trailer a few years ago for a large driveway job that I did in a rural area. It was the same cost to buy a trailer and haul it myself VS paying the have the agregate hauled in.
    Just want to make sure I'm all set up right to start working.
  7. RockinChair
    RockinChair Road Train Member
    4,918
    12,256
    Feb 19, 2012
    CC, TX
    Many years ago when I was running an indump those were called cheater boards. They serve two purposes: they help keep material contained when your trailer is fully loaded, and they also protect the top of your trailer from impact of the loader operator is being careless.
    OldRed98 and okiedokie Thank this.
  8. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    Buy a piece of aluminum and do it once........
  9. Arctic_fox
    3,859
    19,392
    Sep 16, 2016
    Yup them boards are a life saver. Place i did belly for a few years back had 2 trailers down for a month because they had a new loader bend the #### out of the top of the dumps that didnt have them and full on crack them on the 3 that did.
  10. REO6205
    13,172
    60,482
    Feb 15, 2014
    California.
    Out here they're called bang boards. Most everybody with bottom dumps or end dumps use them.
    We always kept few made up ahead of time, painted, pre drilled, and the hardware taped on in a baggy. Quick change.
    Running a loader used to be an old-timer's job in the pits and quarries but now we see a lot kids loading. Some of them think faster is always better.
    D.Tibbitt and okiedokie Thank this.
  11. canadianredneck
    canadianredneck Light Load Member
    229
    104
    Jul 26, 2012
    Western Arkansas
    your memory sucks, depends on the weight of the equipment and the load.
