beet juice before blood pressure test?
Discussion in 'Questions From New Drivers' started by 1278PA, Apr 21, 2016.
  1. 1278PA
    1278PA Road Train Member
    1,170
    1,026
    Dec 5, 2015
    Is it true that beet juice will lower your bp if you drink it the night before a bp test? Since i'm borderline pre hypertension 130+ over 87-91 i would think if it works i would pass no problem.
    I also just read online that when they test your bp if your back is not supported in a chair your numbers can go higher by 5+. So i will make sure i sit in a chair with a back support.
  3. Straight Stacks
    Straight Stacks Paper Cha$er
    2,930
    20,768
    Jul 18, 2015
    Alabama Gulf Coast
    "Beets" the hell outta me?
  4. 1278PA
    1,170
    1,026
    Dec 5, 2015
    good one lol
    Straight Stacks Thanks this.
  5. dngrous_dime
    dngrous_dime Road Train Member
    3,150
    5,765
    Jan 28, 2014
    Lansing area, MI
    Maybe get pickled before you go in? Thins the blood, therefore lower pressure...... :p
  6. FLCRACKER
    FLCRACKER Medium Load Member
    344
    203
    Oct 11, 2013
    Lorida, FL
    Take 1 or 2 asparin a day for a week before will help lower it . And lay off the caffeine too.
  7. A21CAV
    A21CAV Road Train Member
    1,848
    2,156
    Oct 4, 2011
    Laredo, TX
    Anything under 140/90 is good for a two year card . You should be good if you don't jack it up by stressing over it .
    BTW , its really cheap to see a doctor and get on the meds . Mine are $4 each (2 prescriptions ) at Walmart . The doctor visit and blood tests cost less than $200.
  8. pattyj
    pattyj Road Train Member
    22,474
    20,138
    Jul 19, 2008
    Sioux City,ia
    I'm not on any medicine my BP was fine when I took my physical last Thursday.I didn't elevate my back just sat normal and relaxed.Since their BP machine was on a different wall then where the table is I sat in a regular chair.I would suggest staying away from all caffein salt and ciggarettes the day you have your physical.Drink juice and relax.The slightest bit of tention can cause BP to rise.Also don't forget there are many other things in physical you need to pass.My physical took two long hrs.
    NavigatorWife Thanks this.
  9. crb
    crb Road Train Member
    1,676
    1,374
    Dec 1, 2009
    USA
    My us borderline fot physical, always normal at my dr.
  10. lagbrosdetmi
    lagbrosdetmi Box Monkey
    547
    985
    Jul 1, 2014
    Detroit
    Good god, mine takes about five minutes, if that. Concentra special.
    I get the white coat syndrome too. Always wondered if popping a valium would work.
    NavigatorWife and Diesel Dave Thank this.
  11. pattyj
    22,474
    20,138
    Jul 19, 2008
    Sioux City,ia
    When was the last time you had a physical?Some are more thourual these days.But at least I'm good for two yrs.
