Beads, rings, centering sleeves?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Luwi67, May 16, 2017.
  1. Luwi67
    Luwi67 Heavy Load Member
    746
    484
    Oct 24, 2012
    Long island
    I would like to get some up to date info and opinions on wheel end balancing. Most of the stuff I read is a few years old.
    I've had centramatics on the steers for three or four years with no issues however, I want to put something on my drives (11r 24.5) and my trailer (spread axle 22.5)
    My choices are Conteract beads, Balance master rings, Dynabeads, Centramatic rings, and the True balance centering sleeves. As always I want the best bang for the buck.
    Of course each website states their stuff is the best but, I'd like to here from you guys in the real world, the pros and cons of each product you tried and their longevity and reliability.
    I do have an old Jeep with 35" tires that I've been running the Off Road Dynabeads for 5 or so years and they have been doing a great job.
    For the drives it seems most prefer Counteract beads.
    Which product delivers the best bang for the buck or does each one have it's pro as well as con.
  3. Bean Jr.
    Bean Jr. Road Train Member
    5,467
    9,697
    Mar 30, 2014
    One thing I think is important, true balance, despite its name, does not balance the wheel. There is a relatively large clearance for hub piloted vs stud piloted wheels. Using one of their 3 products, that clearance is greatly reduced, and the wheel is centered much closer to center.
    But if it's out of balance, it's still out of balance, so it should be used with a balancing system.
    I have only driven trucks with Centramatics, and the ride was smoother.
    hdtrv, KB3MMX, Oxbow and 1 other person Thank this.
  4. boneebone
    boneebone Road Train Member
    2,294
    2,365
    Mar 13, 2009
    I've had Centramatics on all three axles of my tractor and I can honestly say, they are worth the money.
    Before I installed Centramatics on the Steer axle, I was lucky if my Steers would last 50k miles before they would start getting irregular wear patterns.
    At first I attributed it to the Steers being unbalanced, so I would always have them balanced on a machine, but I still had the same problems.
    I finally decided to purchase a set of Centramatics and for the first time, I had a set of Steers last me over 100k miles with no irregular wear patterns.
    I've owned my tractor for 13 years and have gone through at least three sets of Brifgestone R283 Steers before I finally installed a set of Centramatics in 2011 and since then, I went through a set of Michelin XZA3+ that lasted over 100k and I'm currently on a set of Bridgestone R287's and they are wearing beautifully.
    I also have Centramatics installed on my Drive axles. I am using Bridgestone M726EL's tires and I have no issues whatsoever with them.
    Personally I feel Centramatics work well enough without any issues and you can't go wrong with purchasing them.
    KB3MMX, Luwi67 and Bean Jr. Thank this.
  5. Luwi67
    746
    484
    Oct 24, 2012
    Long island
    Thanks for the replies guys.
    Definitely not putting beads in my spread axle trailer tires so I'll probably give the Balance master rings a try.
    For the drives, I wish there was some more input from people who have run the Counteract beads for some time. I'm not excited about breaking down 8 drives to put beads in without more reviews.
  6. rollin coal
    rollin coal Road Train Member
    13,083
    25,868
    Mar 29, 2008
    TN
    I run counteract beads in all of my tires and have for several years now. I also have tru-balance centering sleeves on all axles for the same time frame I've been running the beads in my tires. I don't have any balance or wear issues my truck rides very smoothly. Got excellent even wear on my last set of retreaded drive tires before I replaced them earlier this year.
    Years ago I had centramatics. I still have them laying around somewhere. Useless. Don't waste your money. Let me ask you how does a 3/4" diameter tube with some balance media balance out the foot print of those drive tires sandwiched in between them like that? It doesn't because it can't.
    Luwi67 Thanks this.
  7. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    iv had some issues with the beads, might be me or maybe not dry enough air but iv had better luck with no balancing at all than with the beads, lots of people swear by them though so your millage may vary
  8. rollin coal
    13,083
    25,868
    Mar 29, 2008
    TN
    Yeah you have to be careful putting them in. Definitely don't want them wet or water in the tire. Go easy with the tire lube when mounting and don't get it all over everywhere on the rim. Use a quality tire lube that will dry to nothing and don't use dawn soap or some other shade tree lube.
  9. boneebone
    2,294
    2,365
    Mar 13, 2009
    It doesn't balance the tires individually, it balances the whole rotating axle assembly as a unit.
    I have them on my Drives and my Drives are evenly worn, unlike other Drives I have seen on other tractors and the thread is feathered and chunking.
    I don't believe having Centramatics on your axles will make your tires worse, and on some trucks the drivers may feel they are a waste of money, but like everything in life, one size doesn't always fit all.
    Bean Jr. Thanks this.
  10. rollin coal
    13,083
    25,868
    Mar 29, 2008
    TN
    There's no way that little narrow 3/4" diameter ring balances the whole rotating assembly of your drive wheels. You know when they balance tires they put lead weights on both the outside and inside of the wheel. Think about that for a minute then think about that run sandwiched in between your drives.
  11. Prom Night Dumpster Baby
    Prom Night Dumpster Baby Medium Load Member
    646
    473
    Jan 12, 2012
    Bug Tussle, TN
    Just bought a 17 lb pail of Esco ceramic beads for a little over a hundred bucks.
    These beads are quality. Very heavy and you can't easily crush them.
    Put them in my car and my buddy's Prostar steers that could never get balanced perfect. Smoothed out the ride on both.
    First is to get tires spin balanced, then add beads. I've had trouble with these different tire shops constantly getting different results every time they spin the same tire. it's not perfect, so the beads complement the lead weights.
    No big deal to put them in. Just jack tire off ground, deflate and pry enough bead away to stick in a small hose like a 3/8" fuel line or similar.Just big enough so the beads don't jam it up. Use a small funnel on the end of the hose and pour in the recommended amount. Air up tire and you're done. Don't forget your jack!
    Haven't used them in my own truck yet cuz my Michelin tall rubber is running smooth as is.
