Battery q. Gel vs Acid.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Pablo-UA, Aug 12, 2012.
  1. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    It is time to change batteries now. So I got a choise - Gel ore Acid. People say gel batts are beter, but they wont working at below zere temperatures so what about idea to mix two acid and two gel in one box?
  3. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,538
    Jul 30, 2009
    Mapleton Depot,PA
    The gel batteries have a different charging rate and profile than a regular acid battery and mixing them in the same box would probably make for an uneven load, which would then probably wear out one or the other type of battery. Kind of like putting in one new battery in the set, instead of replacing them all.
  4. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    Yep, I understand) thanx for info)
  5. V8Lenny
    V8Lenny Road Train Member
    1,016
    130
    Aug 3, 2008
    Europe
    AGM is the way to go. Works in hot and cold.
  6. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    AGM.... too expencive. Seems to me I'll stay with acid. The problem of acid that there are no really maintanace free batts. Anyway driver has to add distiled water, especially when it is hot and many drivers do it when they have to find someone to help with jump start and it is usually in winter when it is late to do it, batteries are bad..... Gel needs less attention.
  7. Markvfl
    Markvfl Road Train Member
    1,103
    338
    Nov 29, 2007
    Apopka, FL
    It sounds like you made up your mind.
  8. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    I have an idea to add box with two batteries for cab and sleeper only. I wanna separate them from other truck with big relay (200A from aircraft). Relay is closed when engine is running (I wanna use alternator D+ output). All sleeper systems would be powered with additional batteries (light, TV, radio, auxially heater, electric A/C and invertor). It is a good alternative apu.....
  9. daf105paccar
    6,564
    7,293
    Apr 15, 2012
    Pablo,i use plain rain water in batteries.(not tap because off chalk)
    My batteries last more then 5 y and i do only short regional(starting the engine 30 to 50 times per day)
  10. GP1500SC
    GP1500SC Light Load Member
    91
    32
    Sep 10, 2011
    mo
    Something that often gets over looked is the battery connections that will hurt a battery in series as much as anything, by over charging a battery and cooking it.
    keep them clean and it will help them live longer.
  11. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    OMG, Truck is back and what do I see? Lost nuts and only one battery connected!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Yep, truck starts with one battery!
