How long can we run the bunk heater before the batteries die? And we run an inverter to power a laptop, or to make coffee, and we charge phones and stuff. We also have a cooler type fridge that runs off a cig outlet. I'm just curious how long you can go before you have to start the engine and charge the batteries. We have a 2018 freightliner cascadia. I'm getting talked to about my idle time, but I dont want to be stuck with dead batteries either.
Battery life...
Discussion in 'Questions From New Drivers' started by MBAngel, Feb 25, 2019.
I ran the bunk heater, laptop to watch movies, and the 12v cooler.
That said if they have a problem with you idling make them buy you a hotel or install an APU. Or thell them to #### and go get a job that treats you like a human.alds, D.Tibbitt, firemedic2816 and 4 others Thank this. -
Lol, well, they just say I idle a bit too much. My response is, I wont be idling if I'm moving, now will I? Keep me running and I won't be idle to idle, lol. They're understanding of the cold weather they've been driving me through.
Thank you for the answers. I've been afraid to just use the bunk heater without the truck running. That heats without the engine running? Not like a car heater? I'm a car gearhead, I dont know enough about semis yet.D.Tibbitt Thanks this. -
The condition of your batteries, how many you have, and their capacity are all factors in how long you can run stuff. You'll be the best one to know how long by turning on the key periodically and checking the voltage while you're running the stuff you want. If you run the batteries until they're almost dead, it wears them down quicker so they hold less with each time you charge it.
For the most part, 11.6 is a low battery, 12.8 is a charged battery. Keep it above 12.0 and it should last longer.
When I don't use my battery charger and generator, I can go 10 hours with the bunk heater and fridge and wake up around 11.9. It will be less when it's colder outside. I will usually run the truck right before I go to sleep to get the engine and coolant temperatures up and charge the batteries. Then in the morning the truck is easier to start.D.Tibbitt, Just passing by and MBAngel Thank this. -
Let those two numbers sink in.... She had about 80 drivers and I wasn't in the top 10 at 57%....
And it's basically like a gas furnace in your house. It burns diesel in an open flame (in a fire box) and pushes air through it it heat up the air. -
Awesome, love the technical info. Now I know what to watch to gauge my own stuff. Thank you!
A new truck like that should have an alarm and a low battery shutoff that should protect you against a dead battery. Have you checked with fleet management to see if the truck is so equipped?
MBAngel Thanks this. -
Your truck batteries are not deep cycle batteries where you can deplete them and then charge them up again over and over, you will ruin your bank of batteries by doing that.
So consumption is critical, knowing how to power-shed things to minimize your consumption is important and getting alternative power sources is a good idea.MBAngel Thanks this. -
You need to “talk to them” about why they don’t properly spec an OTR tractor and why you’ll be looking at other job options while you’re sweating in the sleeper this summer.
Most if not all newer trucks have battery drain protection circuitry. They will start shutting off non-critical circuits as the voltage drops to protect from getting into a situation where there is insufficient voltage to crank the engine. -
4 battery trucks normally have no issue with 10 hrs in colder weather .. 3 battery trucks are really dependent upon battery condition ... I normally warmed up interior a bit extra at 1000 rpm before shutting down which helped insure batteries were fully charged
