Installing one. Can I just use it to break the ground to frame? Splice it between batteries and frame. Instead of breaking the positive wire between battery and starter. Any reason not to?
Battery disconnect switch
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Rideandrepair, Nov 11, 2023.
You can install on ground side. Just make sure you open all main grounds at the batteries thru the switch. Not the starter ground. Anything still grounded to the batts can still draw current.
Oxbow, singlescrewshaker and Rideandrepair Thank this. -
Just curious, why would you need one? If you have a draw draining the batteries, one should find the fault. The only reason one would be needed is an anti-theft device.
Rideandrepair Thanks this. -
