Battery disconnect switch with Inverter
Discussion in 'Kenworth Forum' started by chinaboy, Jan 10, 2023.
  1. chinaboy
    chinaboy Bobtail Member
    Hi guys, I have a Kenworth t660 which has two battery disconnect switches installed outside the battery box. When switches are turned off, that kills all power to the truck. I just installed a 2000-watt inverter directly to one of the batteries negative and positive battery post and works great.
    My question here is, how can I wire the inverter so that the power is also killed to the inverter when the battery disconnect switch is turned off?
    Thanks in advance.
  3. lester
    2,915
    7,846
    Jan 2, 2012
    NW, Iowa
    Simple, wire it in at the switch
    Goodysnap Thanks this.
  4. S M D
    S M D Road Train Member
    2,396
    3,406
    Mar 15, 2012
    sacramento ca
    Add another breaker between the power source like the factory ones. You cut the wire between the inverter and the batteries and add the breaker. but, if your inverter has a on and off button it shouldn’t drain the batteries while off anyways. So I wouldn’t bother.
    chinaboy Thanks this.
  5. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    Pick one of the main battery shutoffs. Shut it off. Put your inverter hot cable on the lug that does not have power on it while the switch is off.
    chinaboy and lester Thank this.
