Battery cut off switch.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by GreenPete359, Oct 31, 2020.
  1. GreenPete359
    GreenPete359 Road Train Member
    2,144
    5,075
    Oct 21, 2017
    Driving my recliner
    What amperage should i be looking at? The one i’m looking at is 350amp consistent & 2,500 for 5 seconds.
    Big Switch 500 with Lock-Out Bracket
    I’m also interested to hear if you guys would put it on the positive side or ground side?
    this is for my ‘79 Pete has a Big Cam Cummins running 4 Batteries & 12 volts.
  3. AModelCat
    154,581
    Always on the ground side.
    Allegedly it arcs less.
    Also. If the switch happens to fail and ground out internally, with it on the positive side it will likely burn the truck down. At least if its on the ground side it won't.
    Roger McG, GreenPete359 and InTooDeep Thank this.
  4. GreenPete359
    2,144
    5,075
    Oct 21, 2017
    Driving my recliner
    you settled that. Thank you.
    Pretty much all boats have a cut off switch & they all have them on the positive side, so when i was told put it on ground i naturally questioned it.
    AModelCat Thanks this.
  5. AModelCat
    154,581
    Everything I've ever worked on with a disconnect has had it on the ground side.
    I'd imagine with boats being fibreglass you wouldn't have to worry about it grounding out. Fibreglass is a great insulator.
    GreenPete359 Thanks this.
  6. pushbroom
    pushbroom Road Train Member
    1,777
    7,253
    Sep 1, 2012
    Petes always run them on the positive. Not sure it makes much difference
    Oxbow, Last Call, spsauerland and 2 others Thank this.
  7. Inderjit
    Inderjit Heavy Load Member
    716
    704
    Sep 17, 2017
    Kenworth always installed the disconnect switches on the positive side as well.
    Oxbow, GreenPete359 and spsauerland Thank this.
  8. spindrift
    spindrift Road Train Member
    3,233
    12,905
    Dec 2, 2014
    Texas
    How do you determine whether or not the amp rating of the switch is correct for your specific application?
