Batteries in the Freightliner Trucks?
Discussion in 'Freightliner Forum' started by SLI2009, Mar 16, 2016.
  1. SLI2009
    SLI2009 Bobtail Member
    Mar 16, 2016
    What are the standard issues with batteries in the Freightliners? What is the best battery that you have found and why?
  3. blairandgretchen
    13,212
    70,209
    Dec 9, 2011
    South west Missouri
    Get 750 CCA, over 1000 CCA.
    Same price, but the lead plates are closer in the 1000 CCA so corrosion (sulphation?) leads to shorts quicker than 750.
    If that makes any sense.
    Buy from Freightliner - and you get warranty coverage at any TA/Petro.
    Keep the receipt.
  4. blairandgretchen
    13,212
    70,209
    Dec 9, 2011
    South west Missouri
    Alliance, I think is the brand.
  5. ipogsd
    ipogsd Heavy Load Member
    977
    515
    Jun 13, 2012
    Alliance sucks, 3 cascadias, 3 sets of batteries with an average of about 130k. I replace this last set with Interstate AGM's marine grade. 3 year replacement at any interstate dealer. Not cheap, but you get what you pay for.
    Tip, marine batteries have both screw and post type connectors. You may have a hard time with the cables.
  6. Yves kanevil
    Yves kanevil Medium Load Member
    522
    465
    Jan 10, 2016
    Nighthawk
    Best batteries are cat batteries. I just replaced them in my truck. They were 9 years old and truck has 48000 hrs on it. I bought a new set of cat batteries hopefully they last just as long.
  7. cdub304
    cdub304 Light Load Member
    162
    68
    Dec 7, 2009
    Rockford,IL
    Well I like interstate but if I am correct its only like 3 companies that make all the batteries so go figure. I just try to replace mine every 2years because that's when the warranty expires. Havent had a problem out of them yet. Bad thing at the freightliner is they pull from all 4 batteries to start.
    bzinger Thanks this.
  8. Scott72
    Scott72 Road Train Member
    2,747
    1,758
    Apr 7, 2013
    Anybody have the Maxwell? I'm considering pulling the trigger on one of those, then just buying 3 other batts for house loads.
    BigSky Thanks this.
  9. jbee
    jbee Medium Load Member
    664
    619
    Jun 3, 2011
    NC
    Odyssey 2150 series. They ain't cheap, but they kick butt. Mine are going on 2 years and have yet to have any issues. Period.
  10. Ridgeline
    22,101
    113,191
    I just finished putting batteries in most of the trucks - Interstate for the normal batteries and Maxwell starting modules for starting the thing. I did the alliance batteries for a bit, then went to AGMs which ended up slowly going down in performance because the regulators on trucks are not setup for those types of batteries That was a waste of money) then went to interstate a few years ago for the original group of trucks I bought and decided to just use them from now on.
    The group of batteries gets replaced at once, none of this one here or there, it is easier to keep track of things. I had one truck that came with the Maxwell unit from the original owner and it works without issue so I made the investment into getting one for each truck and have two extra for anything I buy in the future. I may put one in my pickup to see how it works for that.
    AModelCat Thanks this.
  11. JAYRODPA
    JAYRODPA Light Load Member
    157
    109
    Dingmans Ferry pa
    I have always had good luck with battery's from tractor supply. just make sure all your battery's are the same C.A. ( cranking amps ). one that is a higher or lower with screw up the rest.
