Balancing steer tires
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by mile marker 27, Jun 6, 2020.
  1. mile marker 27
    mile marker 27 Road Train Member
    1,229
    1,633
    Dec 4, 2019
    Fixing to mount new 24.5 steers, on the W9 and was wondering if you guys use the bead bags for balancing? I’m wanting to mount them this afternoon or tomorrow(Sunday) and the tire shops are closed. Have you guys ever substituted anything else for bead bags?
  3. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    Spin balance with weights for me..
    I hated the beads......actually it was a powder that I used.... brand name equal maybe..
    Crude Truckin' Thanks this.
  4. LumbraX
    LumbraX Medium Load Member
    394
    443
    Sep 12, 2015
    Orlando, FL
    I’ve had good luck with balancing beads on all my tires for at least 4 years. I’m going to replace my steer tires as well on Monday. The ones on are 2 Chinese Tires that were installed in June of 2018. OTR from 2019 until today and FL intrastate from June 2018 until January 2019. They are at 5/32 evenly all the way around. All my drives were installed same time and are also Chinese and are sitting at around 7/32.
  5. mile marker 27
    1,229
    1,633
    Dec 4, 2019
    How many ounces of bead might you put in each 11R 24.5?
    Snailexpress Thanks this.
  6. Luwi67
    Luwi67 Heavy Load Member
    746
    484
    Oct 24, 2012
    Long island
    12 oz in each tire for dual
    14 oz steer.
    mile marker 27 Thanks this.
  7. xsetra
    xsetra Road Train Member
    5,094
    6,940
    Aug 21, 2011
    Spin balance and balance rings for me.
    I've had internal balance material plug up the valve stem
  8. Luwi67
    746
    484
    Oct 24, 2012
    Long island
    I've used ceramic Dynabeads for years in my trailer and drives. They are very effective but, they do have their drawbacks.
    Centramatics have been on the steer tires for longer and they do perform. Steer tire woes vanished after install. I will likely remove the beads from the trailer tires in favor of centramatics. Beads can stay in drives for a while.
    tommymonza Thanks this.
  9. tommymonza
    tommymonza Road Train Member
    4,519
    12,848
    Sep 10, 2013
    S.W. Florida
    Do you have them spin balanced first ?
    Anybody use bubble balancers anymore?
  10. Luwi67
    746
    484
    Oct 24, 2012
    Long island
    No, as per Dynabeads and Centramatic spin balancing first is not necessary or recommended.
