Can someone refer me to the proper legislation regarding the requirement of baffles in tanker trucks? We are transporting waste water in a recycled milk truck and we want to make sure that it is legal in Ontario. Thanks.
baffles
Discussion in 'Trucking Industry Regulations' started by Mario Villeneuve, Jan 10, 2011.
Call the MTO to find out. They will be able to direct you to the web site or someone who can let you know the requirement.
Food Grade I know can not be Baffled calle di hauled it in the past. Most Tankers are not baffled for one reason Getting them CLEAN if your going to change Products. Dealing with Surge or Slosh is just part of the job when pulling a tanker. Kinda a nice feeling when 48-50K pounds hits you right between the shoulder blades aint it.
They often use old fuel tankers to haul waste water and liquid or liquefied solid waste. These are baffled, when you see an old food grade or smooth bore pressed into such service, these aren't baffled.
Your province may have rules governing what type of tanker can be used for it, otherwise a tank small enough to carry the legal weight and be almost full, will have less sloshing and hammering from liquid surge. The baffled tanks will have little surge but still be tippy in turns because the load shifts to the side. -
DOT tanker design specifications allow baffles. You will find them mostly in MC 303, MC 306 and DOT 406 elliptical trailers usually aluminum and used for fuels. Not all of them will be baffled.
You also find them in Cryogenic 'thermos bottle' trailers used for liquid oxygen, Liquid nitrogen, etc.; we were told that feeling slosh in them was a sign that it was time for a re-build as the baffles had become detached.
Most chemical and food trailers will not be baffled, not because you can't clean behind 'em BUT because the shipper can't check that you got it clean. The technology exists but the customers won't buy it.
Slop is directly related to product density and weight. Sulfuric acid at 15.63 lbs/gal means a 48K payload is only 3250 gal.
Worse was a large tanker w/ a light alcohol or a thin solvent like acetone, you could put 7500 gal in an 8000 gal tank, it didn't slop as much as 'jiggle'... -
Most washbays have multiple spinners and have the capability to clean thru the washouts, especially when doing a 'pre-solve' on something like a fiberglass resin or some other gooey sticky and viscous product that has to be cut from the sides and top of the barrel.
These same openings are used to induce simple jets of steam when cleaning out evaporators like acetone and similar solvents like some denatured ethanol. Steam and a blow job is usually the cheapest cleanout.
The larger Sellers and Butterworth spinners are used for solution [detergent or caustic] washes and are placed in the manway often using a large 'false dome' on chain fall. These are usually fed by 2" hoses. At Matlack we used 50hp pumps to feed the solutions.
Compartments are a fact of tanker life, you usually pay the standard tankwash price plus a 'per compartment' fee for the extra holes.
