Baffled vs smooth bore
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by HiramKingWilliams, May 10, 2024.
  1. HiramKingWilliams
    HiramKingWilliams Heavy Load Member
    794
    1,256
    May 15, 2019
    State of Jefferson
    Are the any other types of tankers that use baffles besides fuel?
  3. ibcalm19
    ibcalm19 Road Train Member
    1,463
    2,435
    Nov 30, 2015
    Pennsylvania
    It would depend on what you are using the tanker for if you order it with baffles
    Crude Truckin' Thanks this.
  4. Crude Truckin'
    Crude Truckin' Alien Spacecraft
    2,377
    6,501
    Oct 22, 2016
    North Dakota, Eh?
    MC-331
  5. lual
    lual Road Train Member
    4,389
    7,900
    Oct 22, 2020
    SW Georgia
    If my math is right -- cryogenic tanks, as well as LPG trailers....are also baffled.
    Someone else correct me -- if incorrect.
    -- L
  6. Dave1837
    Dave1837 Road Train Member
    1,396
    4,335
    Nov 16, 2019
    Pennsylvania
    I think you can get any type of tanker with baffles. A lot of chemical and food grade carriers don't get them because they're expensive to wash out. Lots of LPG and asphalt trailers have them. I actually didn't think fuel tankers had baffles cause they're compartmented
    special-k and HiramKingWilliams Thank this.
  7. Lazer
    Lazer Road Train Member
    1,729
    2,730
    Jan 22, 2017
    Fuel tankers will generally have baffles, depending on the compartment size.
  8. Judge
    84,584
    Some 20’ isotank chemical tanks have baffles,
    Some of these, not all, bulkhaul tanks had them.
  9. RockinChair
    RockinChair Road Train Member
    4,928
    12,277
    Feb 19, 2012
    CC, TX
    Yep. MC 307 as well, and vacuum tankers.
    I don't know about MC 312, but I would certainly hope that they're baffled considering that they haul dense liquids.
  10. wis bang
    wis bang Road Train Member
    3,348
    3,918
    Jan 12, 2011
    Levittown, PA
    I remember Liquid Carbonic instructing cyro drivers to report any slop as it was a sign the baffles had come free and it would soon be time for a tank rebuild as it was usually the trailer having a hard time maintaining a good vacuum indicating it was rebuild time.
    I purchased an older Heil vacuum tank that was a straight round barrel and around 1/4 of the way in from each head, on opposite sides, was a support blocking about 1/3rd of the tank circumfrence but I wouldn't consider that a baffle.
    Chemical producers do not like baffles as they cannot check how clean those areas are thinking any residual = automatic contamination.
    Having filtered a few rejected loads I can say contamination happens often enough WITHOUT baffles so one can understand how the shippers look at the subject.
    ChicagoJohn and Crude Truckin' Thank this.
  11. mustang190
    mustang190 Road Train Member
    2,827
    6,064
    Jan 18, 2011
    Florida Panhandle
    Baffles are illegal for food grade.
    Unless a chemical trailer is dedicated for a specific product and that product only all trailers are smooth bore. It’s way to expensive and difficult to clean a baffled tank.
