Bad switch or beacon lights
Discussion in 'Ask An Owner Operator' started by Wyoming Jim, Oct 2, 2022.
  1. Wyoming Jim
    Wyoming Jim Bobtail Member
    15
    9
    Jun 23, 2013
    My beacon lights on my '17 389 just stopped working. When I tap on the left light, it briefly flashes once, then stops. I've checked out the fuses both inside the truck and under the hood. They're all good. So, 1) what is the chance it's the rocker switch? 2) How do I check to see if the switch is bad). Thanks in advance.
  3. InTooDeep
    4,981
    37,363
    Jan 17, 2016
    Carmichael CA
    If it flashes when you tap on it I would say the light is your problem
    MartinFromBC, 77fib77 and D.Tibbitt Thank this.
  4. D.Tibbitt
    140,665
    Take a test light, ground the wire then tap the power wire with the test light . if test light comes on, then wire is good and beacon light is going out... If test light doesnt flash, then either u dont have a good ground for the test light or ur wire is bad. To find if u have a bad ground, probe a known wire that has power in the area until u find a good ground, then use that to probe the beacon light wire... Then u trace the wire back to where it goes , and repeat test until u find the problem..
  5. abyliks
    abyliks Road Train Member
    3,742
    8,691
    May 2, 2010
    ludlow MA
    Check the grounds?
    Roger McG and ProfessionalNoticer Thank this.
  6. Wyoming Jim
    15
    9
    Jun 23, 2013
    Thanks. I appreciate the advice.
    D.Tibbitt Thanks this.
  7. fortycalglock
    fortycalglock Road Train Member
    6,150
    6,581
    Jun 25, 2011
    Tourist Town, FL
    If you tapped the beacon and it lit up, it’s the beacon or connection at the beacon. Why would you think it’s the switch?
    ProfessionalNoticer and 77fib77 Thank this.
  8. Numb
    Numb Crusty Curmudgeon
    3,934
    8,733
    Jan 30, 2012
    Charlotte, N.Carolina
    beacon light?
    never heard that term before.
    the directional light, right?
  9. abyliks
    3,742
    8,691
    May 2, 2010
    ludlow MA
    amber stobe that’s about twice the size of a beer can
    Numb Thanks this.
