Bad Starter , Won’t Crank On, Shorted the Alternator with Screwdriver
Discussion in 'Refrigerated Trucking Forum' started by 1arko23, Oct 5, 2022.
  1. 1arko23
    1arko23 Bobtail Member
    15
    10
    Jul 28, 2020
    I am a new driver and my Reefer Unit is Thermo King Precedent S600. Today I went to start the reefer and it had clicking sound with power but not cranking on. After the jumper cables it turned on and I got a new battery for it. After installing the new battery the clicking sound came back again but wouldn’t turn on. I talked to a veteran driver and he said that my starter is bad. He said I can try putting a screwdriver connecting the two bolts on the starter to crank it on and not to turn it back off. My father got involved and made the mistake of doing that on the alternator instead of starter and now my front panel will not turn on at all. Figured he shorted something. We opened the front panel and checked fuses and they all seem ok. What could have happened by shorting the alternator. Any help will be appreciated before we take it in for service.
    Thank you
  3. xsetra
    xsetra Road Train Member
    5,092
    6,939
    Aug 21, 2011
    Your problem to begin with, sounds like a bad alternator. It wasn't charging the battery.
    Shorting out the alt. May also have shorted out the battery. Instead of having a low charged battery situation. You now have a battery with no charge, so the reefer doesn't have any electric feed to turn on.
    Let us know what repair was needed.
    Good luck.
    D.Tibbitt Thanks this.
  4. bad-luck
    bad-luck Road Train Member
    3,245
    5,943
    Nov 16, 2013
    Baltimore, Maryland
    I run reefer only and can wrench a lot of my own stuff. But when it comes to my reefer I pay someone to work on it.
    hopefully you didn't fry the micro, because if you did it was $2000 about 5 years ago, can't imagine what it is now.
    @reeferwrencher i am sure he can help you.
    reeferwrencher Thanks this.
  5. reeferwrencher
    reeferwrencher Medium Load Member
    556
    1,474
    Aug 4, 2018
    Put a jumper wire from the positive terminal of the battery to the positive terminal of alternator. Turn on the controller and see if it powers up.If it doesnt then check positive wire,I believe there is a fuse link on that circuit,at least there is on the c600.Remember you are still likely going to need a starter as well.
  6. DRTDEVL
    DRTDEVL Road Train Member
    1,706
    3,418
    Jan 27, 2013
    Austin, MN
    I'm still trying to wrap my head around mistaking an alternator for a starter...
    shanman, Pup97, RJM1953 and 3 others Thank this.
  7. abyliks
    abyliks Road Train Member
    3,746
    8,692
    May 2, 2010
    ludlow MA
    not something i cheap out on either, I just pay TK, that way if god forbid, something does happen when loaded, I can also show the insurance company that it was properly maintained the whole time
    I do keep a spare starter and alternator in my side box though
  8. bad-luck
    3,245
    5,943
    Nov 16, 2013
    Baltimore, Maryland
    Thats smart
  9. MAMservices
    MAMservices Medium Load Member
    446
    2,936
    Aug 9, 2021
    They both round and have wires running to em. ‍♂️
  10. DRTDEVL
    1,706
    3,418
    Jan 27, 2013
    Austin, MN
    And one is belt-driven, the other drives the flex plate by bendix gear, so...
    RJM1953 Thanks this.
