Bad Motor Mounts Signs...
Discussion in 'Trucks [ Eighteen Wheelers ]' started by JakeBrakeChampion, May 4, 2011.
  1. JakeBrakeChampion
    JakeBrakeChampion Light Load Member
    55
    19
    Apr 14, 2011
    Pennsylvania
    Well I have asked many questions about this problem i have been having.(thank you all for the responses) I belive i have narrowed it down to motor mounts. When loaded heavy and shifting or pulling out from a stop it feels like the trans is gonna come through the floor lol... I can deffinatly feel the shifter moving when applying throttle. Especialy when theres lots of torque like when crawing up hill in low gear it will feel jumpy and lots of movement in the shifter.. Sound like motor mounts? T800 with a n14 460e
  3. grump
    grump Light Load Member
    74
    29
    Jan 1, 2011
    PA
    Jake brake thats your problem i had a t 800 for 6 years replaced mine 4 times , mine had a flat design with angled end with one bolt in the center when mine would get bad the gear shifter would hit me in the leg when going in a low gear loaded using the jake . The kw replacements r not that great but atro makes a good aftermarket i use their torque rod bushings last a long time they make the motor mount out of polyurathane and steel hopes this helps!
    mitchlocke Thanks this.
  4. kwforage
    kwforage Road Train Member
    1,047
    472
    Jun 3, 2007
    Wisconsin
    grump - Did you replace your own mounts? How bad of a job was it to replace them? Any tips. I have a new pair waiting to go in my T6. I am going to do it while switching my trans. Sounds like you had the same kind of mounts I have. Kind of a \_____/ shape with a hole in the center. They each come with a washer too.
  5. JakeBrakeChampion
    55
    19
    Apr 14, 2011
    Pennsylvania
    Thanx.. I noticed your truck is a tri axle and you live in pa.. My t800 is a tri axle dump. Im in pa.. Have you been workin with the marcellus shale?
  6. grump
    74
    29
    Jan 1, 2011
    PA
    Yes i did replace them myself all i did was take the bolt out the cat had a flat pad on the block by the mount used blocks of wood with good bottle jack lift the engine one side at a time high enough to slip out the old n in with the new . i dont like the kw mounts they suck and dont last long thats why i would go with the poly ones that atro makes.
  7. grump
    74
    29
    Jan 1, 2011
    PA
    Yes i live north west along I 80 and no not a dump its a log truck with loader.
