Bad drag link?
Discussion in 'Ask An Owner Operator' started by RunningAces, Oct 3, 2021.
  1. RunningAces
    RunningAces Road Train Member
    1,263
    2,513
    Jul 2, 2017
    OLDSKOOLERnWV Thanks this.
  3. Dino soar
    Dino soar Road Train Member
    4,789
    26,858
    Dec 8, 2017
    That is no bueno.
    Is that nut torqued down on there?
    shooter19802003 Thanks this.
  4. AModelCat
    154,242
    That nut is loose. Good chance the upper steering arm is wallowed out and no good now.
  5. scottied67
    scottied67 Road Train Member
    10,816
    12,615
    Mar 14, 2010
    california norte
    Twist the draglink as well. It should not be loose like that. Easy fix though. I replaced mine, it was as easy as removing the cotter pins and nuts and putting the new draglink on and tightening the nuts back down and putting in new cotter pins. Ironically the original size nuts that came off were 33mm and the new nuts were 1 5/16ths, so I had to go back to the hardware store and buy a new wrench.
    Bean Jr. and feldsforever Thank this.
  6. RunningAces
    1,263
    2,513
    Jul 2, 2017
    Thanks guys I'll get it fixed up.
    Bean Jr. Thanks this.
  7. RunningAces
    1,263
    2,513
    Jul 2, 2017
    One more question, I just took the pin out and tried to take the nut off the side that isn't connected to the Pittman arm. Instead of the nut turning the bolt turned with no resistance. Is it broken inside or what? There is nowhere to grab a hold of it with another wrench to stop the entire bolt from turning.
  8. AModelCat
    154,242
    Its not a bolt, its a ball stud. The shank is tapered to match the taper in the upper steer arm, which locks it in place.
    You might have to get a jack or something and push the drag link back up into the taper to hold it.
    That ball stud should have some resistance to turning. It could be worn if it spins with no resistance. With that nut being loose my advice would be to remove it and inspect the taper on the ball stud and the tapered hole in the upper steer arm. If its been pounded out from running loose it may never seat correctly again.
  9. Final Drive
    Final Drive Road Train Member
    1,573
    2,505
    Jan 21, 2015
    See what happens when your bored and hungry...
    feldsforever, JoeyJunk and Vampire Thank this.
  10. ProfessionalNoticer
    2,941
    7,852
    Apr 25, 2021
    Tighten it as tight as you can get it. Then back it off just enough to line the holes up to replace the cotter pin. If the link or the bar still have any play after it's all tightened back up then replace them both because they could be egged out from the play depending on how long it's been going on. I'd love to know why the cotter pin isn't there.
    Bean Jr. and shooter19802003 Thank this.
  11. OLDSKOOLERnWV
    17,804
    268,363
    Looks like someone finger tightened the nut and called it good. Definitely not suppose to do that.....
