I was seeing check engine lights but they come and go . Been dealing with this for over two months nothing happens to truck and yes I did take it to mechanic he did replace what the codes said like putting new Nox sensor and also he dumped the Def and put new one I did not use bulk but Box boxes of Def so I still get them lights here and there. Today I noticed and my engine sounds different with these lights now. What can be wrong or what should I do next to get it fixed ?
Bad DEF quality and Nox sensor ? Check engine lights but they come and go
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Sekhri, Aug 18, 2017.
Page 1 of 5
we use the bulk containers of DEF as we get onsite fueling. if the fuel truck has his supply of DEF, they fill up our tanks, so that too is bulk.Sekhri Thanks this. -
Time for a new mechanic. Codes NEVER tell you to replace anything. A computer can only tell you what's going on in a circuit, which includes, sensors/switches, wiring and plugs. There is a diagnostic procedure to follow to identify the problem. An intermittent problem like yours is the toughest to pinpoint. The exact fault code (SPN and FMI) will help, also any thing else you can tell us. Is there anything pattern or conditions that may be associated with it? Like does it do it more in rainy or damp conditions vs. dry weather? Cold/hot? Loaded/empty? Bumy vs. smooth roads? Anything you can say about the fault is another clue that may help.
JohnC123, AModelCat, Oxbow and 1 other person Thank this. -
What year is your truck. I have a ghg14, 2016 Cascadia.
On this model of emissions there is a little tiny def fluid filter that is in the def line right where it goes into the one-box. It can get a build up of white slime that inhibits the amount of def going into the chamber and give these sort of codes. Called a def Doser inlet screen.
Just a thought and easy to check out.
https://ddcsn-ddc.freightliner.com/cps/rde/xbcr/ddcsn/608-14.pdf -
You can avoid the white slime by keeping your DEF tank full.
Reduced tank levels cause crystalized buildup in the tank that falls off and produces the slime you describe... -
What we need to help you now is the SPN and FMI of your fault code. It looks to me like you do not have a NOx sensor fault at all. NOx Conversion efficiency is more of a logic fault, not a sensor problem. From the limited information I have, I can guess that your NOx sensors are working correctly, but it is not sensing enough of a NOx reduction. Meaning you have a problem in the SCR system. Could be many things, most common would be a clogged DEF doser. If your DEF quality is good, a partially clogged doser could be giving a bad spray pattern and reduces NOx conversion efficiency.AModelCat, Oxbow, SAR and 1 other person Thank this. -
If it is a DD15 Detroit, can be as bad as a worn out SCR oxidation coating of the catalyst. If that were the case the whole one-box would have to be changed.
Page 1 of 5
