Bad Cascadia crank case filter
Discussion in 'Ask An Owner Operator' started by Keepforgettingmypassword, Feb 2, 2023.
  1. Keepforgettingmypassword
    Keepforgettingmypassword Heavy Load Member
    738
    937
    Jan 11, 2022
    Can any one tell me if a blown oil pan gasket could be a system of this?
    Three gaskets in 6 months
  3. ducnut
    ducnut Road Train Member
    2,429
    7,214
    Dec 31, 2010
    SPI
    Not sure what engine you have, but, a bad oil separator and/or plugged filter will build excess crankcase pressure and something has to give. I’m surprised none of your techs have mentioned it or investigated it. It’s a fairly common problem.
  4. AModelCat
    154,278
    Usually the crank seals are the weak points on an engine.
  5. Ridgeline
    22,103
    113,210
    Yeah, I just replaced the front seal on an ISX because of excessive crankcase pressure.
  6. AModelCat
    154,278
    At least it wasn't the rear.
  7. Keepforgettingmypassword
    738
    937
    Jan 11, 2022
    A tech did bring up the crank case filter yesterday, And because of the cold I can't do it my self. So I wanted some feed back before i started playing part darts at the shops. But he was the first tech to anything about it. So im trying to be diligent.
    If I catch a warm snap I will put it on. But it looks like I will be having a shop do it this weekend.
    I don't know what engine excatly, I had two differently dealers swear I had two different engines.
    I do believe it is the 415 horse power dd13. Thats what the parts have been fitting anyway.
    ducnut Thanks this.
  8. Ridgeline
    22,103
    113,210
    Had that too on another truck a while ago.
  9. ducnut
    2,429
    7,214
    Dec 31, 2010
    SPI
    On a previous Volvo/DD13, the oil separator went bad and it started blowing oil out the breather tube. A oil separator is common for a DD13, as those bits only last so long. You need to have him at least check it or even replace it, while he’s there.
  10. Keepforgettingmypassword
    738
    937
    Jan 11, 2022
    Thank you. I will check this out also.
    ducnut Thanks this.
