Backing up into docks- Any advice ?
Discussion in 'Questions From New Drivers' started by Nightwind8830, Oct 8, 2013.
  1. Nightwind8830
    Nightwind8830 Medium Load Member
    419
    192
    Jul 13, 2013
    Chicago,IL
    I'm just learning how to do the 45 degree backing into a dock in class and im not very good at it. I'm having difficulty learning how to maneuver the trailer into the square of cones that is our "dock" . its tough for me to judge how to position the trailer and the truck in a straight line from the angle we start out at,like when to start turning the wheel and such.Any advice from drivers or rules of thumb you use ? Not sure if this is something advice will help with or if its a dumb question, but its aggravating,so why not ask.
    Thank you
  3. STexan
    STexan Road Train Member
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    Not having a "square reference" of any sort nearby makes backing difficult even for the most experienced. Backing up to cones is not very intuitive for trying to end up at a "90". Without seeing the situation or scenario you are dealing with, it's hard to offer any meaningful advice other then maybe "rethink" the situation.
  4. muleshoe
    muleshoe Light Load Member
    67
    28
    Jul 4, 2013
    Learning how to back might take you a bit. Don't get frustrated. It'll come to you. If your in doubt, get out and look. Fenders ain't cheap.
    AndrewMemphis Thanks this.
  5. Nightwind8830
    419
    192
    Jul 13, 2013
    Chicago,IL
    Good point... its tough to describe , we start out at a 45 degree angle away from the "dock" and have to back up then turn to maneuver the trailer into the cone square so that the trailer and truck are in a straight line. its hard to describe it further.
  6. BigRigFisher324
    BigRigFisher324 Light Load Member
    128
    84
    Mar 13, 2013
    Practice Practice Practice
    Pmracing and AndrewMemphis Thank this.
  7. joseph1135
    joseph1135 Papa Murphy
    11,340
    27,299
    Nov 8, 2009
    The Highway To Hell.
    Yes. My advice? Don't hit anything.
  8. muleshoe
    67
    28
    Jul 4, 2013
    Learning how to back, is about the toughest thing you can do in this job. I wish I could give you some sort of formula, to help you. But backing is one of those things that you learn by doing. Just don't get frustrated. When you get frustrated, that's when you have to make that call to the safety dept. Just hang in there. It will come.
  9. blairandgretchen
    13,238
    70,566
    Dec 9, 2011
    South west Missouri
    If it's the one I'm thinking of, it's putting the rear of the trailer into that 'box' like it's a dock. It's not the parallel park where you have to end up with the trailer jack-knifed in the rectangle, right?
    STexan is right, a point of reference is handy, like lines in the pavement, or dock lines. But for practice and test you don't get that assistance.
    In the 'real' world, I always liked to line up the truck and trailer in a dead straight line before backing, if room allows. But if they're making you start from a 45 degree angle, then you'll have to learn how to 'turn and chase'. Turn the wheel a little, back up, and then 'chase' the turning trailer with your steer tires, all while aiming for the square cone box.
    As said before . . . practice practice.
    Side note, the whole dynamic is altered depending on where your trailer tandems are set, and the length of the trailer being backed. Shorter trailers react faster than longer ones.
    The only dumb question is the ONE YOU DONT ASK!
    G3Truks and KW Cajun Thank this.
  10. Nightwind8830
    419
    192
    Jul 13, 2013
    Chicago,IL
    You're dead on with what im talking about. you start out at a 45 degree angle away from the cone box and need to back up,watching the tires and trying to line them up with the cones,then you turn the wheel at a certain point so the trailor is parallel with the cones,then back up and get the truck even with the trailer in front and back into the square with the trailer and truck in a straight line. . "Turn and Chase" is what you're doing.,like you said.its tough fo me to back into this "mock dock" and get the trailer backed in straight with the truck straight also.practice does sound best on this one
    blairandgretchen Thanks this.
  11. Nightwind8830
    419
    192
    Jul 13, 2013
    Chicago,IL
    Cant make any promises. this is my face while trying to back the trailer up at an angle:biggrin_25524:.trying to check my mirrors and not hit cones,lol.frustration.hopefully tomorrow goes better
    joseph1135 Thanks this.
