B Trains in the States
Discussion in 'LTL and Local Delivery Trucking Forum' started by Mike2633, Feb 24, 2016.
  1. Mike2633
    Mike2633 Road Train Member
    6,461
    25,988
    Jun 14, 2013
    At Home on The West Side
    I have a quick question, why do we not see more B-Trains here in the states?
    I know that some steel haulers like Valley Transport of Ashland, Ohio have B-Trains, but other then that you don't see them at all. Is it an over all vehicle length thing or is it a weight thing? I know like we disscused in Canada and the Pacific Northwest you can have more weight, but other then that you really don't see to many B-Trains in the states.
    From what I hear the Canadians like them and prefer them over standard A-Train doubles.
  3. cnsper
    cnsper Road Train Member
    5,869
    27,421
    Feb 28, 2014
    weight limitations is the main reason. I think that Michigan and Montana are the states with the highest limits for divisible loads. Other states being 105,500 and with the train weighing in at 17k add that to the truck at 22k and you are looking at 39k tare weight minimum. That only leaves you with 66,500 pounds of payload availability if you can get the axle weights correct.
    Now that same tractor with a 4 axle flat can gross nearly the same. Because of bridge law I go with 103k for that setup but then you are pairing a 22k tractor with a 13k trailer so that puts you at 35k tare weight. You should be able to scale 68k of payload.
    So with a 4 axle trailer, all things being equal, you can haul more product weight.
    road_runner, Mike2633 and carl320 Thank this.
  4. carl320
    carl320 Light Load Member
    98
    67
    Jul 4, 2012
    Somewhere, IN
    I run around Michigan pretty regularly, and it's not uncommon to see 11 axle setups on the highways, including B-trains.
    Mike2633 Thanks this.
  5. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,056
    Nov 18, 2014
    Land of local
    @Mike2633 On the NY thruway you can pull 2 48's I see em all the time. I think they're allowed somewhere around 120-140k
  6. cnsper
    5,869
    27,421
    Feb 28, 2014
    That's the thing, you see them in local or regional areas. I can go 130k in Montana but not any of the surrounding states.
  7. Mike2633
    6,461
    25,988
    Jun 14, 2013
    Ohio turn pike you can do turn pike doubles, Falcon Transport and USF Holland and PI&I as well as DOT Foods sometime pull them.
  8. Russian Rabbit
    Russian Rabbit Road Train Member
    1,701
    1,633
    Jan 3, 2016
    My guess would be convenience? How do unload the lead trailer after you unhook everything?
  9. Russian Rabbit
    1,701
    1,633
    Jan 3, 2016
    i think Florida Turnpike also allows turnpike doubles.
  10. JPenn
    JPenn Road Train Member
    1,829
    1,873
    Mar 5, 2008
    Northern Tier PA
    B-trains (5th wheel on rear of lead trailer, no convertor dolly) are permitted on the NY Thruway, though it may be on a case by case basis. The primary advantage to them is they can be backed up, without the headache of breaking the set or trying to push a squirrelly dolly backward. Depending on axle count, I believe they can gross up to 140K, same as the double 48's. I'd like to see more of them, myself.
  11. sprayed150
    sprayed150 Light Load Member
    137
    121
    Jun 1, 2015
    Fort Lauderdale Fl
    yea, they have a staging area at commercial and the sawgrass on the west side
