I'm a little confused on axle weights. I currently driving a 2012 Freightliner Cascadia, 4 axle tractor. I'm in Washington State. I have 295/75 22.5 wheels. My steers can be 13,200 pounds. How much can be on my drives with my drop down as a group?
Axle weights
Discussion in 'Experienced Truckers' Advice' started by Atlas183, Dec 28, 2022.
PDF weight table.
https://wsdot.wa.gov/travel/commercial-vehicles/commercial-vehicle-permits/legal-vehicle-weighttscottme and silverspur Thank this. -
tscottme Thanks this.
They also need to measure from their lift axle on the truck to the rear trailer axle so that they get their 7 axle inner bridge (with a 4 axle trailer), 6 axle bridge (with a triple), or 5 axle bridge if they have a regular tandem. You will max out your inner bridge and then add on whatever you can carry on the steer axle and that will give you your gross. For example, when I worked for the flatbed company we were licensed for 105,500 gross but most of the trucks bridged out at 104,500 and some were 105,000.
If the OP goes to Oregon then they also need to know Oregon’s bridge chart because it’s different than every place else. My 105k gross truck was only good for 102k in Oregon.Accidental Trucker, Crude Truckin', kylefitzy and 1 other person Thank this. -
Accidental Trucker, kemosabi49 and Long FLD Thank this.
You guys need to run in Wisconsin.
Jubal Early Times Thanks this. -
Crude Truckin' and Jubal Early Times Thank this.
43,500 unless the drop is spaced further up from the drives. Or back. As mentioned from bridge law.
Total weight is about 56ish. If you had 2 drops it's about 60.
My axles are close together. So I haul 43,500. As does the above poster.
Above is a link to federal bridge law which is what's used for most of the west. Good idea to save it or print it.
Some of the east has their own heavy haul rules. They haul more then federal allowed.
