Axle Weights ( Ontario)
Discussion in 'Canadian Truckers Forum' started by keepitsimple, Jan 8, 2013.
  1. keepitsimple
    keepitsimple Light Load Member
    157
    87
    Aug 2, 2011
    ontario, Canada
    what are the legal weights one can have for axles?
    the tractor has 12,000 fronts, and 40,000 rears. Can ya have that much, or is it less?
    The trailer is 20,000 axles, ( tridem) what can we legally run on each axle?
    Thanks
  3. ralph
    ralph Road Train Member
    1,112
    632
    Mar 1, 2009
    At The Key Board
    I'll give you the basic weights BUT it's up to you to make sure you conform to bridge law
    Steer is 12,000
    Drives are 39,600
    Tridem (depending upon the spread) is 51,000
    keepitsimple Thanks this.
  4. keepitsimple
    157
    87
    Aug 2, 2011
    ontario, Canada
  5. alex6999
    alex6999 Light Load Member
    81
    9
    Sep 19, 2009
    Toronto, ON
    9000kg for single axle with singles tires(steer)
    single with dual tires 10000 kg
    tandem 18000 kg = 39900 lbs or with spread - 19100 kg
    tridem 21300 - 26000 kg (depends of spread)
    and see cabcard for maximum gross
    see trucks specs for axels and tires
    drives tires usually can carry 6175*2 = 12350, so this your limit.
    dont forget, to carry 40000 on tadems most tires need 120 psi pressure
    Speedloader Thanks this.
  6. Pullin2
    Pullin2 Crusty Canuck
    1,991
    3,611
    Nov 5, 2011
    Whoville Pub, Long Island
    I thought it was 35 psi ???? ........... Oh wait a sec, that's for the drive axle on my ride-on mower carrying my butt ..........
    Hammer166 Thanks this.
  7. jonboy29
    jonboy29 Light Load Member
    297
    187
    Jul 9, 2010
    Home Sweet Home... SW Ont.
    bet that puppy is overloaded.....
    hahahahaha, just kidding!
  8. jonboy29
    297
    187
    Jul 9, 2010
    make sure to check the front axle limit, 12,000, 18,000 ect. the steer tires on that axle also have to be rated for the weight.
    Can't have a 20,000lb steer axle with regular 12,000lb tires and expect to carry 20,000.
  9. FLATBED
    FLATBED Road Train Member
  10. Pullin2
    1,991
    3,611
    Nov 5, 2011
    You driving a car hauler ? No, I guess not by the wording of the original post. I only ask because some provinces differ with lengths and weights depending on if your are a stinger or not.
  11. jonboy29
    297
    187
    Jul 9, 2010
    I don't think so, he said tridem trailer. And I doubt its an old old ryder trailer. Didn't they have 3 axles with single tires, and a very low drive thru into the belly?
