Axle weight percentages
Discussion in 'Questions From New Drivers' started by Zulufoxtrot, Feb 26, 2022.
  1. Zulufoxtrot
    Zulufoxtrot Bobtail Member
    4
    Do my front and rear axles need to be within a certain percentage of each other?
  3. MACK E-6
    48,113
    219,511
    Not that I’m aware of.
    What exactly do you have going on?
    Zulufoxtrot Thanks this.
  4. Zulufoxtrot
    4
    22k on drives and 38k on tridem
  5. Gliding ProStar
    Gliding ProStar Heavy Load Member
    860
    6,132
    Nov 12, 2016
    Waxahachie, Texas
    Those numbers are fine. I pull a 3 axle step deck and I see axle weights like this all the time. As long as you are not over weight on any axle(s) or over 80,000 total there is nothing wrong with that. Due to the nature of some of my loads I see the same weights as you. You will find that the truck will ride better if you get a little more weight on the drive axles. Mine can feel a little "herky jerky" sometimes where it feels like the load on the trailer is pulling against the truck over bumps or on uneven roads like when there are large gaps between the seams of concrete.
    What are you loaded with right now?
    Malt Ball Cult and Zulufoxtrot Thank this.
  6. Zulufoxtrot
    4
  7. Zulufoxtrot
    4
    Awesome! Thank you for the feedback. Just want to make sure it was legal
  8. bumper Jack
    bumper Jack Heavy Load Member
    887
    4,410
    Dec 5, 2021
    Well technically it depends. Texas and Ohio I think only allow a 20% variance. Some states like Wyoming don’t care. I can’t really say how often any state enforces this though. These numbers are for overweight permits. If you’re legal gross I have no clue if it even matters as long as you’re less than 48,000 on the tri.
  9. kranky1
    kranky1 Road Train Member
    2,253
    8,850
    Sep 16, 2015
    Ontario, Canada
    My understanding is minimum 20% of gross on the drives. I’m not sure if that’s a should or a must. I know B.C. enforces on that.
    beastr123 and bumper Jack Thank this.
  10. kranky1
    2,253
    8,850
    Sep 16, 2015
    Ontario, Canada
    Here in the east we put 57,200 on a 12’ tridem. The lightest jurisdictions up here give you 52,800.
    bumper Jack Thanks this.
  11. tscottme
    tscottme Road Train Member
    Legal is determined by the weight on the axle, not in relation to other axles. On a standard semi-truck pulling a 53 foot trailer that usually means 12,000 lbs on the steer axle, 34,000 of tandem drive axles, and 34,000 on tandem trailer axles.
