Axle hop
Discussion in 'Trucks [ Eighteen Wheelers ]' started by KittyKicker, Mar 30, 2016.
  1. KittyKicker
    KittyKicker Light Load Member
    196
    100
    Dec 27, 2015
    I have a W900L with the AG380 (Flex Air) suspension. The truck has had a bounce to it since I bought it last year. Nothing I do seems to help it. The bushings look ok, I have replaced all of the wheel bearings, brakes, both differentials, all new steel wheels (outers are aluminum), all the u-joints, all the shocks, sticker tires all the way around and had them all balanced. I also checked the axles to make sure they are straight. I recently slid my 5th wheel back to center the kingpin between the axles and the bounce seems to have gotten worse. When I'm bobtailing the bounce comes in at 30, goes away, then comes back between 55 and 65. When loaded, it comes in about 60 and only gets worse the faster I go. Any ideas? I've about had it trying to chase out this gremlin.
  3. daf105paccar
    6,564
    7,293
    Apr 15, 2012
    Driveshaft out off balance
  4. Klleetrucking
    Klleetrucking Medium Load Member
    378
    346
    Dec 11, 2010
    S.C.
    Wow, you've spent a ton of money.
    When the tires were balanced were they checked for radial run out ie. round? I've heard truing the drive tires works wonders. A place in Longview, Tx. gets $70 a tire for truing. As a cheap endeavor, jack the truck up and check the radial run out yourself with a heavy block right next to the tread area. Crude but it might show something. I've improved ride by finding the high spot on each tire of the dual and turned the high spots 180* from each other.
    IMO, a drive shaft problem is a high frequency vibration and not a "bounce" as you described. Again IMO.
    BoxCarKidd Thanks this.
  5. AModelCat
    154,236
    Did you check your steady bearing when you did your u joints? What about your yokes at the transmission and diffs?
  6. Ridgeline
    22,101
    113,190
    What do you mean by bounce?
    Is it when you drive down the road with any load, or bobtail that you have a vibration?
    OR is it that you hit a bump or hole and it bounces?
    I've had both, they are different and it would help us to help you to describe it.
    Klleetrucking Thanks this.
  7. KittyKicker
    196
    100
    Dec 27, 2015
    By bounce I mean that it feels like my tires are going down the road like basketballs go down the court. It isn't a vibration, it really feels like the back axles are trying to come off the ground. Like I said in the original post, when I'm bobtail it comes in at certain speeds, when I'm loaded it just gets worse. I'm out of ideas.
    Stringb8n Thanks this.
  8. KittyKicker
    196
    100
    Dec 27, 2015
    I'm not sure what you mean by "steady bearing." I'm assuming you are talking about the carrier bearing, in which case yes, it was replaced recently and I have inspected it since. The yokes are all good as well, all of the nuts tight as can be.
  9. KittyKicker
    196
    100
    Dec 27, 2015
    I was wondering if the intermediate shaft might be bad, but the mechanic says it doesn't have any play in it.
  10. KittyKicker
    196
    100
    Dec 27, 2015
    Yeah, we checked them for run out and they checked out ok. We did find 1 steel wheels was a little bent, so I replaced them all. Nothing. I forgot to mention I also made sure the ride height is set perfectly per kenworths specs.
  11. AModelCat
    154,236
    What about driveline angles?
    Dino soar and Alberta trucker Thank this.
