Axle flange bolt torque
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Dino soar, Sep 21, 2018.
  1. Dino soar
    Dino soar Road Train Member
    4,789
    26,858
    Dec 8, 2017
    I'm putting the axles back in my 40,000 lb Rears.
    What are they supposed to be torqued at? These are the 15 /16 nuts that hold the axle in on the Hub.
  3. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
  4. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    I usually hit the upper end of that spec sheet. 130-190 is a pretty wide range. 5/8" axle flanges get 185ftlbs.......For me. Especially without axle tapers/wedges. The axles with wedges will tend to stay tight and not leak with less torque but I still hit them all the same.
    Oxbow, snowman_w900, SAR and 3 others Thank this.
  5. spsauerland
    spsauerland Road Train Member
    4,296
    10,886
    May 31, 2010
    West Harrison, In
    I use nyloc nuts and 180 ft/lbs. I have used Stover lock nuts in past, but they always seem to damage stud threads or pull studs out of hub when removing. Nyloc I just melt the plastic insert with smoke wrench when removing.
  6. Batman13
    Batman13 Light Load Member
    110
    45
    May 20, 2020
    What is a 2014 freightliner cascadia??
  7. Goodysnap
    3,694
    8,948
    Jul 12, 2017
    Most all Axles Dana and Mertor alike. Stud size of 5/8" should be all the same torque.
