First of all, I want to say thanks to everyone who has helped in the past with my issues. It has been a huge help.
2016 Freightliner Business Class M2 6000 gallon aircraft fuel trucks
I have an AWD option question, as the manual doesn't tell me much about it. It does go over the Axle Lock feature and says for 'Austere Conditions Only'. I will instruct my driver crews to basically never touch that switch. However, the manual doesn't say what the AWD function is used for.
We're located on the island country of Bahrain, in the Persian Gulf. The trucks are operated on primarily paved surfaces, but they may have an occasion hwere the guys attempt to drive them across portions of sand. I have noticed when off-loading them from the semi flatbeds they were delivered to us on, and also when trying to climb a very slight incline to flat shoulder of the roadway that only the Right Rear set of tires spin. The rest are dead as far as the drive train goes. I had to lock them in to get the truck to a stable and hard surface, and then disengage the lock for normal use.
I'm wondering if the AWD function can be used for more than just short as-needed conditions. Pretty sure our old Oshkosh units had both rear axles operating at all times. I don't want the drivers getting into a lost traction condition, and have them start flipping switches and snapping diffs and such, or spinning and suddenly catching and having the same damage occur. Basically, is there anyway to get more than just the R/R set operating, or will it have to be a 'stop the spin, flip the switch, creep onto good ground and then disengage again' type of thing? What is the difference between the AWD function and the Axle Lock function? They seem redundant to me.
Thanks in advance.
AWD Question (Business Class M2)
Discussion in 'Trucks [ Eighteen Wheelers ]' started by DoubleGs, Nov 18, 2016.
Your interaxle lock can be used to send equal power to the front and rear drive axles, so that in a spinning situation you will have one wheel on both axles turning. AWD switch engages the transfer case that engages your steer axle.
Interaxle lock can be left engages as normal differential action will still occur across the axles. If you had a differential lock you wouldn't want to leave that engages as you need differential action to make turns, ect.. AWD shouldn't be left engages as there is a gear reduction that takes place and that steer axle and drive axles do not operate at the same speeds, which on hard paved surfaces can be an issue.
Last 6 of the VIN on one of your trucks and I can take a better look at it's actual setup. -
HL9846. Thanks.
The interaxle lock switch, AWD switch and transfer case range switch apply to your vehicle. It seems that none are suggested to stay engaged at all times, only when needed.
You can select the inter axle lock and transfer case lock independently from each other. Having just the transfer case lock on these trucks makes me wonder if they aren't already sending power to 4 wheels at all times with an unlocked transfer case. Knowing drivers though, I would inform them if they get stuck, wait for all wheels to stop spinning, lock the transfer case, lock the inter axle, then pull to better traction and unlock.
Thanks everyone for the inputs. I do think it'll be best to brief them all to leave them all alone, unless they get into a traction-lost situation, and then to use one or a combo only from a stop and only long enough to get on good ground, then disco.
All the good information aside; your picture highlights one of my pet peeves with trucks... and Internationals in particular (in my experience). Why can they not group switches for similar or related functions together? Put all the axle function switches together. Instead, they just randomly distribute them. And they often are not the same from truck-to-truck.
Case-in-point: we operated eight different Prostars over about three years. All of them were equipped with inter-axle locks, differential locks (four-way lockers) and traction control cancellation. The traction control cancellation is important when in mud or deep snow conditions... as we were often. Instead of grouping the switches together so they were easily used when needed, they were randomly distributed and not even the same from truck-to-truck. Ugh! -
I believe the m2's have enough wiring back there to move the switches to the holes you want them to be in. Prostars I am not sure I wasn't inside the dash of many of those trucks, usually only for a SART module.
The M2 we work on that is 4x4 is a manual transmission and all the switches are together. We just had to replace the transfer case in it this week. They use this truck to spread lime in fields and the oil cooler for the transfer case started leaking and they had no idea. The transfer case does not hold very much oil and it burnt it up. Locked up on him while driving down the highway at 45 MPH. Left marks for a ways.
