Average life of a clutch in an autoshift and transmission maintenance
Discussion in 'Ask An Owner Operator' started by RunningAces, Jul 15, 2023.
  1. RunningAces
    RunningAces Road Train Member
    1,263
    2,513
    Jul 2, 2017
    What do you guys think is about the average life of a clutch. Mine is an Eaton Autoshift 10 speed with 650k miles on it. Other than changing the transmission fluid at 500k miles what other maintenance should be done on a transmission to keep it in good shape for the long haul?
  3. Siinman
    Siinman Road Train Member
    5,156
    12,909
    Mar 5, 2017
    Kansas City, MO.
    Not sure on the Eaton but on a IShift you change oil at 500K and they are expected to last 1Mil plus. Warranty is up to 5 years/. 750,000 Miles.
    Added: Clutch is about the same but depends on how a person drives to be honest.
  4. RunningAces
    1,263
    2,513
    Jul 2, 2017
    I've been looking into it a bit and it looks like a few guys change their air pressure regulator because it is relatively easy to do. It's supposed to get gunked up after years of use which can lead to hard shifting.
    77fib77 and Siinman Thank this.
  5. DixonM
    DixonM Medium Load Member
    329
    694
    May 22, 2022
    The truck I drive has an automatic 12 spd and today it gave up the ghost I believe it needs a clutch at least I hope that is all sounds like the throw out bearing is gone a lot of squealing coming from the transmission when it tries to get into gear and now has codes on dash all with a 138000 miles on it and I just got it out of the shop 10 days ago and had it checked out because it was throwing codes and here I sit.
    I wish this truck had a 13 spd manual instead
    77fib77, Opendeckin and RunningAces Thank this.
  6. scoobertdoo
    scoobertdoo Road Train Member
    1,512
    2,601
    Nov 11, 2020
    Manual is cheaper, go trade it
    I was looking at going to a super condo but someone told me my 2016 is worth 10k right now, mostly due to manual transmission
  7. abyliks
    abyliks Road Train Member
    3,742
    8,691
    May 2, 2010
    ludlow MA
    More then likely something will break before the clutch wears out, just had mine done at 50% but had a couple of broken springs
    Siinman and 77fib77 Thank this.
  8. flood
    flood Road Train Member
    4,157
    4,020
    Dec 25, 2010
    Clutch will last about as long as a standard if you have the eaten fuller advance.. replacement cost will be about the same as a standard because it uses the same clutch.
    You will most likely need a new X-Y shifter around 700k-800k... as soon as it starts to shift funny or make a loud click in 1 or more gear changes.
    Siinman Thanks this.
  9. DixonM
    329
    694
    May 22, 2022
    Well my truck will be getting a new clutch this week 138000 miles on it hopefully it will be done by Friday
    It was running great then out of the blue it started squealing from the throw out bearing and putting up codes on the dash.
  10. RunningAces
    1,263
    2,513
    Jul 2, 2017
    ####, hope it was under warranty.
  11. lester
    2,914
    7,842
    Jan 2, 2012
    NW, Iowa
    Grease works wonders. Or is that a maintenance free throw out bearing
