Automatic vs manual mpg
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Electronic Cowboy, Dec 6, 2014.
  1. Electronic Cowboy
    Electronic Cowboy Light Load Member
    53
    9
    Nov 18, 2014
    LaLa Land
    Currently I drive a 2015 automatic Volvo. I get 7.6 mpg. I'm looking to get a 2014 manual Volvo but I'm told there is difference in fuel mipage, where the auto gets more. I don't see how as this thing is crap going uphill, always slowing down uphill empty or not and it shift like two to three times. What you guys getting for your standards?
  3. JoeBear
    JoeBear Light Load Member
    103
    46
    Jul 18, 2014
    Houston, Tx
    I'm in a 12' KW 660 getting around 7.6mpg 10speed
    Electronic Cowboy Thanks this.
  4. russtrucker
    russtrucker Road Train Member
    1,767
    337
    Mar 27, 2012
    Central PA
    I drove a 2012 cascadia with 10 sp, going 68 mph, and gets 7.9 mpg. When cruising on us route 30 in oh at 64 mph, it gets 8.4 mpg.
  5. brian991219
    brian991219 Road Train Member
    2,921
    5,811
    Aug 10, 2013
    Lords Valley, PA
    The bold is why the automatic is said to get better fuel economy. It is designed to shift when needed to keep the engine rpm and torque in spec for the best fuel usage not always the best speed up the hill. It takes extra fuel to maintain speed, which you will give it in a manual by controlling the gears to achieve maximum speed, not always the best fuel economy. An automatic will beat a manual for fuel most of the time, it takes a really skilled and disciplined driver to maximize their fuel economy, an automatic does this for most drivers.
    magoo68, Deezl Smoke, RERM and 3 others Thank this.
  6. beemergary
    beemergary Light Load Member
    229
    112
    Apr 11, 2014
    In a car application a manual trans always did better because of the slippage involved. They came out with lockup converters to take care of the slippage in high gear. Like brian991219 said it takes a skilled driver too maximize fuel economy and know the torque sweet spot of his engine.
    russtrucker Thanks this.
  7. barroll
    barroll Road Train Member
    1,096
    544
    Nov 23, 2010
    Southwest Michigan
    My smart shift does all kinds of stupid things to kill my fuel economy. Runs the engine up to 2200rpms and sits it there, takes 8-15 tries at revmatching a gear when shifting, shifts back and forth between gears uphill, and keeps the engine in gear while stopping and downshifting until 4th gear.
    I was a disciplined driver in a manual, getting 7.1-7.5mpg regularly in a dpf truck, but this piece of junk has been doing 5.5 mpg lifetime, and anywhere from 4.4-6.9mpg on paper. Breakdowns from the transmission alone have run me about $1500 a year as well.
  8. Electronic Cowboy
    53
    9
    Nov 18, 2014
    LaLa Land
    Never had an issue shifting. Knew where that spot was. I can understand though with maintaining speed on hills. I've been told before...well basically not to use all that power going up hill, but meh. I just hate a slow climb if I don't have to.
    OldHasBeen Thanks this.
  9. Cowpie1
    Cowpie1 Road Train Member
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    That "auto shift will get better mpg than a manual" assumes typical fleet type of driver. For an experienced driver who really pays attention to how they do things, I think it is a wash. A good driver tries to understand the power curve of their engine and find where it does its best work at the best mpg. It is mostly a selling/marketing thing put out by the OEM's to state that auto shifts will always get better mpg. Remember, they are primarily targeting fleets with this marketing stuff.
    And the auto shift has limits. It has to be programmed to take full advantage of the engine, loads and conditions. Many just take the truck out and drive it and have fits over where the auto shifts and such. It needs to be taken in and have shift points reset to where they need to be and other settings. A auto shift has over 100 parameters that can be set to adjust things where they need to be. Like most things, the factory just sets stuff at a basic level and ships it.
  10. hawkjr
    hawkjr Road Train Member
    1,652
    638
    Feb 28, 2010
    Virginia
    I was a 2nd year driver getting 7.0 in a 2010 KW with a 485 Cummins 13spd, running 65-68 pulling most of the time 42K+. Companies stop being cheap and spec it out right you could run highway speeds and still get good fuel mileage.
  11. russtrucker
    1,767
    337
    Mar 27, 2012
    Central PA
    My T600 is not just an ordinary fleet truck. Had 475 hp, 10 sp, and 3.70 rear axles. Tuned up to 500 hp and runs like a champ but one thing sucks that is stock mbn, turbo, 10 sp, killer muffler, and has 3.70.
