Looking to for some advise from anyone using them. Approx. cost and if they're cost effective ie. better fuel economy, longer tire life. We have 2 tri axle dump trucks and a tri axle 30 ton float trailer that we haul heavy equipment on, up to a 27 ton Cat excavator. The trucks are in and out of gravel pits and construction site with the usual hazards of nails, screws etc. We also run long stretches on the highway, some jobs are a 6 hour drive away. We've blown 10 tires in the last year. The expensive steer tire blow out happened immediately after running over a piece of metal on the highway so this wouldn't have helped in that situation. 5 were run on low air pressure and the other 4 were slow leaks from nails etc. The 5 low air pressure blowouts were the same driver so I got him a new tire gauge and showed him how to use it and to stop checking tire pressure by kicking the tires. Thanks.
Automatic tire inflation systems
Discussion in 'Trucks [ Eighteen Wheelers ]' started by wall_404, Jul 24, 2015.
Page 1 of 3
I ran for Landstar for two years and they have the auto-air on their trailers. I did a lot of drop and hook so I had a lot of different trailers but during that time I had 0 blowouts. I even picked a trailers that had flats with the bead unseated from the rim and after driving 25-30mph for 2 miles the tires bead was set and was fully inflated. Stopped at a shop and got a nail punture repaired but didn't have to waIt for a service truck.
Thanks! I'm hoping I can show the boss this would be cheaper than blown tires, repairs and downtime. Better fuel economy would be a bonus.
We use them on trailers and they are great, looking at ~$500 for a complete system, so they pay for themselves if it saves 1 road failure. Ours are Hendricksons, which has a white light on the trailer that comes on when air is flowing into the tires to let you know there's an issue.
I've never seen ones for steers. I have seen them for drives, but they were not like the trailer systems that use air from the truck. They were actually compressors mounted the axle flanges. We didn't opt for that, it was over $1000 to do 2 axles and hey didn't look so reliable. They are heavy on 1 side, so they stay level and tire rotation causes the pumping.
IMO, on a truck, you might be better off with a tire pressure monitoring system rather than a tire airing system. The monitoring systems only have a sensor in each wheel that transmit pressures to a dash mounted unit. I've seen them for $400-500 and a few for a little over $900 that'll do truck and trailer.wall_404 Thanks this. -
Haven't used a system for drive tires. We have used both meritor and Hendrickson systems for trailers. We have had a couple of blowouts on retreaded tires. Another thing you still need to keep an eye on the tires, if the stator filter going to a wheel gets too dirty it may give a false reading to the system and the warning light won't come on alerting you to slack tire. If your trailer is properly aligned the systems do help with tire wear.
Thanks!! The last one the guy blew both tires and when all the costs were added up it was over $900.00 plus 5 hours downtime because he wrecked the hub too.
One think I've noticed with the Hendricksons is that you have to snug the wheel hoses up with pliers or it wont seat in far enough to open the valve. Finger tight usually doesn't cut it. Other than that, they're very simple systems that have been little trouble. The worst part about them is 1 light for 8 tires, with a small leak, the tires still come in full, so you have to check every tire, usually with soapy water to find the leaker.wall_404 Thanks this. -
i forget what exactly the cost is for a retrofit, i have a thread from a few years ago when i had it installed on my belly dump a few years ago. the system has been great. biggest problem i have had is tire tecs breaking the airlines off the hub.
I have Meritor PSI on my new trailer. its awesome! quoted $2200 at utility dealer to install it another trailer.
I love them. Saved me from a shop quite a few times. I'll show up for a drop and hook and find a really low tire. After rolling a few miles its aired up and good to go.
I run crossfire wheel equalizers on my drives. So nice to have a single point of air fill up and a quick gauge to see your over 100 psi.
Page 1 of 3
