ATO2612D VS AT2612D What is the Difference? Volvo I Shift Transmission
Discussion in 'Volvo Forum' started by Siinman, Jan 5, 2022.
  1. Siinman
    Siinman Road Train Member
    5,435
    13,973
    Mar 5, 2017
    Kansas City, MO.
    Wondering what the difference in these two I Shift transmissions are?
  3. Siinman
    5,435
    13,973
    Mar 5, 2017
    Kansas City, MO.
  4. loudtom
    loudtom Road Train Member
    1,717
    2,803
    Aug 26, 2016
    I don't know for sure. They're rated for the same amount of torque, so I'm guessing the housing, input, and output would be the same, but the gears would be different sizes to change the ratio. @nasriza would probably know.
    Siinman Thanks this.
  5. Siinman
    5,435
    13,973
    Mar 5, 2017
    Kansas City, MO.
    Maybe just need to update programming?
  6. nasriza
    nasriza Road Train Member
    2,398
    2,074
    Feb 1, 2013
    Chicago, IL
    No one is direct drive one spin of input one spin tail shaft usually faster diffs with this one is over drive one spin input around 1.4 spins tail shaft with slower differential ratio. Xe pck Volvo is ato with 2.64 ratio super fast 1500rpm around 80mph. At with 2.64 1500rpm around 70 to 72 mph
  7. nasriza
    2,398
    2,074
    Feb 1, 2013
    Chicago, IL
    Can not be interchanged if they r u need someone really good with programming to make trans shift right might loose a lot of pulling power going from at to ato or loose top end going from ato to at.
    best way I can explain hope this helps.
    Siinman and loudtom Thank this.
  8. Siinman
    5,435
    13,973
    Mar 5, 2017
    Kansas City, MO.
    So am I understanding right, it can be installed without different parts but it is going to be a big issue with fixing the programming?
  9. nasriza
    2,398
    2,074
    Feb 1, 2013
    Chicago, IL
    Not a big issue but u really have to know what you are doing in order to make it work being that also need to change programming in abs module and also vecu and Ecm Volvo dealer is no help they have never seen #### like this. On top of everything you need to make sure ratios work together mechanically if u put at with 3.23 you won’t be able to get over 60 mph without blowing pistons out of block. So there is a lot of things that need to be looked at but technically it would could be done I’ve done it a few times people wanted more pulling power and less speed so went to at from ato but it’s a process to do right anyone can bolt it in but other #### is a different story.
  10. Grant Industrial Trans
    Grant Industrial Trans Bobtail Member
    41
    15
    Jan 10, 2016
    Macon, Georgia
    I know I'm jumping on an old thread, but can anyone tell me the difference between a ATO2612D and a ATO2612C? I'm not finding much on the internet, about the 'C', it looks like most trucks have the 'D" version. Unfortunately our truck has the 'C' model, and it just puked. It has a PTO and wetline, but we had that put in, so I wouldn't think that had anything to do with it being a "C" model. Any thoughts? I don't want to toss 10k at the wrong solution. THANKS!
