Atmospheric pressure
Discussion in 'Ask An Owner Operator' started by Rob2isking, Jan 28, 2022.
  1. Rob2isking
    Rob2isking Light Load Member
    108
    23
    Apr 30, 2015
    What’sa normal reading for atmospheric pressure? I have a 2007 Pete 379 with a c15 Acert MXS. CatEt reads 13. I put a new sensor in and it shows status flag -altitude adj- I’m getting low boost, no check engine light. Just trying to go through the steps of diagnosing
  3. scoobertdoo
    scoobertdoo Road Train Member
    1,512
    2,601
    Nov 11, 2020
    At sea level 14.4 it goes down the higher you are
  4. ProfessionalNoticer
    2,941
    7,852
    Apr 25, 2021
    Make sure nothing is grounding out anywhere. Could cause a derate.
  5. Rob2isking
    108
    23
    Apr 30, 2015
    If it was Derald, wouldn’t the ecm show something on cat et?
  6. Rob2isking
    108
    23
    Apr 30, 2015
    I mean derate*
  7. ProfessionalNoticer
    2,941
    7,852
    Apr 25, 2021
    I put a temp sensor on my CAT a few years ago and one of the wires was grounding out but I didn't know it until later while driving down the road. Initially it seemed fine than all of the sudden I lost power and didn't know why. About a half hour later I figured it out. Never got a CEL or anything. Not saying this is your issue but I would certainly investigate the wiring as well as the sensor itself. It's not that uncommon to get a "new" sensor that's faulty directly from the seller.
  8. Rob2isking
    108
    23
    Apr 30, 2015
    I still haven’t figured this out. My atmospheric reading is 13. I put a new sensor In but theirs still status flag that reads “altitude adj active”. My air filters aren’t even a year old and I’ve cleaned them out a few times since I’ve bought them. Replaced the stmospheric sensor. No CEL only status flag showing when I plug in Cat ET. Says that the altitude adj means the ecm cuts back on fuel. I can’t get over 34 lbs of boost now. C15 acert In a 2007 Pete 379
  9. Rob2isking
    108
    23
    Apr 30, 2015
    I’m also in southern Oklahoma, so I’m not very high above sea level
  10. 062
    062 Road Train Member
    6,143
    33,182
    Oct 20, 2013
    What is the voltage at the plug?
