Assessing truck battery health
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Hegemeister, Nov 14, 2021.
  1. Hegemeister
    Hegemeister Road Train Member
    1,912
    1,660
    Jun 16, 2012
    Mechanicsburg, PA
    Hey all.
    Need to know what is the minimum battery voltage you might expect after the truck sits unused for about a week with the nighttime temps in the 30s or 40s.
    Thanks.
  3. MAMservices
    MAMservices Medium Load Member
    446
    2,936
    Aug 9, 2021
    12.9 volts. If not, your batteries are suspect.
    Hegemeister and Ross_Tech Thank this.
  4. Ross_Tech
    Ross_Tech Light Load Member
    133
    133
    Aug 31, 2021
    It depends so many variables. From how clean your batteries are, to how many ecu's you have in the truck. A battery disconnect switch is a good investment if your truck is going to sit. Below 12.4 is a discharged battery, 10.5 or lower and it's junk.
    Hegemeister Thanks this.
  5. Hegemeister
    1,912
    1,660
    Jun 16, 2012
    Mechanicsburg, PA
    After sitting a week in 30s to 60s temp, I measured 12.2 v
  6. Hegemeister
    1,912
    1,660
    Jun 16, 2012
    Mechanicsburg, PA
    12.9? I measured that short term, but they didn't hold that voltage long term when they were brand new.
  7. Ross_Tech
    133
    133
    Aug 31, 2021
    That's not terrible. I imagine it still started. You can do a parasitic draw test to find out how much your batteries are being drained by things like the ecm and radio, which requires a small amount of power to keep the memory alive. Also keeping the batteries clean will prevent battery case drain. The best way to assess the battery's health, is to fully charge them, and load test them individually.
  8. Hegemeister
    1,912
    1,660
    Jun 16, 2012
    Mechanicsburg, PA
    They are holding 13v so far. About 1hr.
  9. MAMservices
    446
    2,936
    Aug 9, 2021
    Ross is correct, it depends on several things and batteries should be isolated and load tested individually to evaluate their condition. Generaly ideal battery voltage with the engine running is between 13.7 and 14.7V. With the engine off, you should get a reading of at least 12.6 volts. If the battery isn't fully charged, it will diminish to 12.4V at 75%, 12V when it's only operating at 25%, and down to 11.9V when it's completely discharged.
  10. Hegemeister
    1,912
    1,660
    Jun 16, 2012
    Mechanicsburg, PA
    Sat overnight and the voltage was 12.6.
    Just testing voltage, the time sitting should play a role when doing just a simple test.
    But yeah, load testing is best, but not always convenient.
