Arrow Truck Sales does not stand behind there trucks!
Discussion in 'Trucker Taxes and Truck Financing' started by freightliner18257, Mar 24, 2021.
  1. freightliner18257
    freightliner18257 Light Load Member
    88
    55
    Mar 8, 2009
    chicago il
    Bought a 2016 international from them, 80 miles later clutch went out and they pretty much told me it is what it is we can’t help. There excuse was they discounted the truck at the time of sale lol. So buy a truck from Arrow and before you pull your first load spend $4k on a clutch and tow woohoo!! Thank you guys!!
    Update so far installed new clutch, new slave cylinder, new air dryer, new nox sensor and towed the truck twice all while its done 3 loads for me 2 of which it had to be towed from! Total out of pocket 3 weeks after purchase so far roughly $8,000. Worse used truck I have ever purchased and worse experience ever there customer service is useless, the salesman cant help at all and the manager Mike is useless but he gave me a discount! Stay away from these guys!!
  3. slow.rider
    slow.rider Road Train Member
    2,005
    4,740
    Apr 4, 2017
    NYC
    Thst sucks. Make a YouTube vid about it, and then when it gets to 10k views, email the link to the manager.
  4. zinita17601
    zinita17601 Road Train Member
    1,317
    1,603
    Aug 19, 2010
    lancaster pa
    Did u buy the truck with warranty or as is?
    Aamcotrans Thanks this.
  5. zinita17601
    1,317
    1,603
    Aug 19, 2010
    lancaster pa
    Sorry,the question was meant for the op
  6. Lucky12
    Lucky12 Medium Load Member
    600
    2,297
    Nov 24, 2019
    slow.rider Thanks this.
  7. slow.rider
    2,005
    4,740
    Apr 4, 2017
    NYC
    There should be an edit button where you can fix stuff like that. :)
    flood Thanks this.
  8. flood
    flood Road Train Member
    4,157
    4,020
    Dec 25, 2010
    So you bought a used truck and
    A: you didn't have it checked BEFORE
    or
    B: thay didn't let you have checked
    Which 1 is it
  9. p608
    p608 Road Train Member
    2,181
    2,991
    Nov 10, 2016
  10. Don379
    Don379 Heavy Load Member
    714
    1,286
    Jan 7, 2021
    I understand your frustration, but clutches are not covered in any warranty let alone if you didn’t purchase a warranty. Not to add insult to injury but many of us have bought used trucks. With any used truck, stuff is broken and wore out. That’s up to you tix it. Used truck, when you turn the key off at the end of night, it’s time to start wrenching. Unfortunately for you, you clutch went out and had to get towed. I have had clutch were it but usually that takes time and starts slipping. That doesn’t leave the truck dead in water. If you have linkage failure somewhere and clutch won’t disengage, you can still ram it in low gear to get the wheels goin* and float home. What happened to your clutch that rendered you dead in water?
    Moral of the story, read the fine print and get in writing that they will cover wear items and tow such as clutch. And with used truck, someone most likely traded in becuase it was time
  11. Deere hunter
    1,847
    7,734
    Aug 5, 2017
    Shallowater Texas
    You got that 9090 warranty, 90 feet or 90 seconds which ever comes first! It’s not that they don’t stand behind their trucks it’s just when you buy used truck there’s usually no warranty and whatever happens happens. I’m sorry to hear of your bad luck hope things look up and get better.
    Aamcotrans, Doealex, Matt1924 and 3 others Thank this.
