armrest removal on an elite 80 seat
Discussion in 'Trucks [ Eighteen Wheelers ]' started by lastgoodusername, Mar 17, 2012.
I dont know if this will work but, feel down the shaft where the armrest goes into the cushion there maybe a little button to push in and slide the armrest out.
lastgoodusername Thanks this. -
thanks , i will check that out, i took a quick look earlier and i didn't see a bolt or something obvious like that.
the stop pin for the arm rest is threaded. unscrewing it releases the arm rest.
I don't know if your leaving your armrest off, but I did and I bought one of these http://www.photonage.com.au/images/images/prod/H/H3864.gif to plug the hole. Lowes had a bunch of them, I found one that was a tight fit, worked out nice.
Unzip the end , pull it back, and you’ll see a large allen screw. Back it all the way out and slide the armrest off. If you want to remove the stud, there’s a bolt just above the stud, it takes a 1/2” socket. Screw the bolt out and you can wiggle the stud out of the hole. I moved one from the left side of the passenger seat to the driver seat because it didn’t have one on the left. A bonus is that it makes it easier to get between the seats into the bunk.
