Area Needed for Turnaround
Discussion in 'Experienced Truckers' Advice' started by joejitzu, Feb 1, 2017.
  1. joejitzu
    joejitzu Bobtail Member
    Hi, folks. I'm a civil designer in need of some advice from experienced drivers. In the project I'm working on, trucks (largest 65' end to end) turn off the street into the facility, take a left, stop and are unloaded (no dock). After unloading, they continue across a couple of adjacent lots my client owns (via a verbal agreement that allows them access) and exit back on to the street (creating a giant semi circle).
    My client now wants to build an office with parking on those two lots. Basically, he's selling the back portion of the lots to the adjoining facility, and closing off their exit to the street. Trucks will now have to turn around and go back out the way they came.
    I'm designing their turn around area. I think the trucks will need to make a three point turn, but I haven't been able to find any templates showing how trucks turn in reverse. Done a lot of internet searching, looked at video, and it seems drivers do reverse turns in a lot of different ways.
    The area I set aside for turning is 115' x 148', or 17,020 s.f. (see hatched area in accompanying picture). My question: is this enough room for a driver to turn around, using either a three point turn, or some other method? Your insights are greatly appreciated!
  3. mugurpe
    mugurpe Medium Load Member
    395
    274
    May 5, 2013
    Arlington, MA
    65' end to end looks like the bumper-to-bumper on a very tight daycab setup. My T370 single axle with a 150" WB is 12.8' front bumper to head of the trailer, so that pus a 52' trailer is 65'. Or maybe its 48' trailers and a longer cab? I'd double check that number to start with.
    The area you've marked looks like plenty. No need for a 3pt turn I think if the truck is 65' end to end, a uturn would work. I think someone who knew what they where doing would be able to not even use the hash-marked section and do a 3pt turn in the other part of the lot, but it's hard to say without the measurements.
    SCANIA makes a good truck-driving simulator for free that you might learn something trying out. They're euro trucks but it'll give you a more intuitive understanding of how parking and/or turning around works. Good excuse to get paid to play video games at work anyway right?
    In tight spots, strategically painted lines in the lot make parking a LOT easier so that's also something to consider if space is tight.
    Shock Therapy Thanks this.
  4. Espressolane
    16,963
    102,197
    To turn a truck around, your going to need a fair amount of space. and it needs to be clear space. all the time.
    To turn a truck around using. three point, or K turn, you will need a square of at least 2.5 times the longest truck you expect to have. Most road trucks are about 24 feet " bumper to bumper", add the trailer length minus king pin set, and you should have a good over all working length. you could be looking at a range of 68 to 72 feet. A 72 foot truck will need 180 per side square to turn around.
  5. crb
    crb Road Train Member
    1,676
    1,374
    Dec 1, 2009
    USA
    What type of trucks? 53' van/refer? Spread axle trailers?
    Should definitely be able to do 3 pt turn around, most of the time where I deliver that is how I have to get out and I don't have near that much room. My truck is considerably larger 75-80'
  6. MysticHZ
    MysticHZ Road Train Member
    5,874
    5,676
    May 28, 2010
    I think that should be plenty.
  7. STexan
    STexan Road Train Member
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    I would not design anything that would actually end up requiring a 3 point turn. If you can't make it in a single u-turn without hitting a curb or wall, it will be a constant source of problems (truckers damaging the back of their cab or adjacent walls/curbs/objects). For 53 ft trailers, if they have their tandems set all the way back can almost kiss the back end of their trailer on the way back out. Tandems set way forward generate a lot of tail swing that can damage building walls, etc if they run right up to it before initiating hard u-turn.
    I'll look into required space dimensions and get back to you if you haven't gotten firm number by then. But on cursory consideration, the initial 115 feet seems barely adequate "typically". But if something has to park in the area or breaks down this might make it impossible for others to navigate until such time as the offending object is removed.
    You might refer to this (WB-62 primarily but this is too short for typical 53 foot trailer/otr tractor combo)
    http://onlinemanuals.txdot.gov/txdotmanuals/rdw/minimum_designs_truck_bus_turns.htm
    Shock Therapy and mugurpe Thank this.
  8. mugurpe
    395
    274
    May 5, 2013
    Arlington, MA
    If the space is empty now, get some traffic cones and cone it off and have the next delivery driver who comes though turn around in it.
    MrsWJAA, ncmickey, Bo Hunt and 4 others Thank this.
  9. ZVar
    ZVar Road Train Member
    10,911
    23,825
    Sep 10, 2010
    Flint, MI
    Hopefully this works...
    Take a look with Google Earth of how this place next to where I pick up did it... It's basically just a big 120' circle.
    https://goo.gl/maps/89Y74Bajd1L2
    The easy way is simply asphalt, or even gravel that whole lot and let the the truckers see what's best...
    Lepton1 and crb Thank this.
  10. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,470
    Nov 7, 2007
    Possum Booger, Alabama
    I don't know if you can extrapolate the measurements of this court by the FedEx facility in Midland City, GA by using known standard sizes of parking spaces and what not. This is just barely enough room to make a U turn with an OTR fleet spec tractor and a 53 ft tandem axle trailer.
    https://goo.gl/maps/kUekd4dttbv
    This court in Sanford, FL is not quite big enough for the same setup.
    https://goo.gl/maps/FeVxMw2GpWP2
    ZVar, crb and STexan Thank this.
  11. STexan
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    And please realize, truck-trailer combinations and 3-point turns really aren't a good match and are generally avoided if at all possible by experienced drivers. Even one minor backup that goes a bit too far will damage the back of many tractors hitting the side of the trailer, especially if they "almost" made it but had to back up while the trailer was already almost at the back of the cab.
    Many trucks today have sucked the trailer up as close as possible to the tractor (via 5th wheel position) to enhance fuel economy, this makes it easier and faster for the tractor and trailer to "come into contact" ... a costly repair of a busted cab extender fairing.
    Truck manufacturers purposely keep from creating a turning radius that is so tight as to eventually have the typical trailer from making contact with the tractor in a single, continuous u-turn. Doing a 3-point turn ... all bets are off from that point, especially with todays 53 foot trailers with far-to-the-rear set tandems.
