Are these steering King Pins any good?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by LoneRanger, Nov 30, 2021.
  1. Truckers Report Jobs
  2. bad-luck
    bad-luck Road Train Member
    3,252
    5,956
    Nov 16, 2013
    Baltimore, Maryland
    BoxCarKidd and ibcalm19 Thank this.
  3. jamespmack
    213,562
    I've used Rockwell and Stemco version. Work well, but you must grease them often. If you don't have scheduled maintenance and good about it. They are not for you.
    Pamela1990 Thanks this.
  4. LoneRanger
    LoneRanger Road Train Member
    3,664
    9,449
    Jun 3, 2018
    I grease about 2-3 weeks at most but I don’t drive that much. About 2.2k miles a week.
    Rideandrepair and jamespmack Thank this.
  5. jamespmack
    213,562
    If you grease around 5k you will be fine.
    Rideandrepair and LoneRanger Thank this.
  6. LoneRanger
    3,664
    9,449
    Jun 3, 2018
    Is there no grease needed king pins?
  7. bad-luck
    3,252
    5,956
    Nov 16, 2013
    Baltimore, Maryland
    You MUST grease your king pins! At a minimum, every 2 weeks. Otherwise you will have premature king pin wear.
    Pamela1990 and Rideandrepair Thank this.
  8. LoneRanger
    3,664
    9,449
    Jun 3, 2018
    That I know. I was wondering if there are sealed versions.
    Rideandrepair Thanks this.
  9. bad-luck
    3,252
    5,956
    Nov 16, 2013
    Baltimore, Maryland
    I have never heard of any. I actually grease mine weekly.
  10. Rideandrepair
    17,223
    55,904
    Aug 8, 2015
    I don’t know. Price seems average. I was told once to use a Kysor reamless bushing Kit. Everyone makes the quick kits. I think I’ll stick with the regular ones. Mainly because my originals lasted a long time. Same with all my front end parts. Whatever brand they are, probably Merritor, that’s what I’m using. A bigger concern is if your spindle is egg holed out. New ones are expensive. They can be bored and sleeved. Axle Surgeon does them. I’ve heard that if it’s needed, it’s best pricewise to have them do the whole Job. Easyrider has an excellent video on YouTube doing kingpins. Reaming them doesn’t seem very hard. Makes for an exact fit. The reamless spiral are ideal for a do it yourselfer. I think I’d use any of the Major brands. Some aftermarket kits are so cheap. Can’t help but be Leary of them.
    BoxCarKidd and LoneRanger Thank this.
