I originally intended to stick to smaller trucks, but am now curious about 18 wheelers. Are there any electrical outlets for small ac appliances (such as a blender, a dorm fridge, etc.) in the sleeper?
Probably won't go OTR, just thinking about it right now, but the idea has a little appeal. I'd like to be able to make smoothies and maybe do some juicing as well. (I'm fighting off blood sugar problems, and eating only raw fruit, vegetables, nuts, seeds, and drinking water and juices from my juicer is helping alot.)
Thanks.![]()
Are there any electrical outlets in the sleepers?
Discussion in 'Questions From New Drivers' started by Lysander, Oct 27, 2007.
They make appliances with cigarette plugs or you can get an inverter for your truck to use your appliances. -
The best inverters will have a power on/off and a circuit breaker on them. The biggest offered in the truckstops is a 2500 watt hard wired to your battery system. The cost is about $250.00 to $300.00 The newer trucks will have 3 or 4 power outlets for your "appliances" you can get an adapter and split 1 power outlet (cigarette plugs) into 3.
What I have done is install a 1500 watt inverter in my side box above the battery box and bought a shop extension cord with an on/off lighted power switch and surge protector built into it as well. I ran the shop power strip to the tv console cubby and mounted it inside. Now I can plug my household appliances into the power strip that is connected to the inverter that is connected to the batteries. I keep the inverter off until I actually want to cook something. When I am done I turn it off (I can access the inverter by lifting the bunk or stepping outside the truck and opening the side box door to turn it on or off. I carry a microwave, a toaster oven, a sandwich maker, an electric cooler, a cpap machine, and a laptop computer in addition to my cell phone. Looking at a larger truck refrigerator but the cost is around 500 bucks. -
Thanks, folks.
Do most trucks have the 12v car outlets in the actual sleeper? I am going to GTI to start with a trainer. I haven't gotten my list of what to bring/not to bring yet, but I am betting that an inverter is on the not to bring list.
So just to be prepared i am getting a 12v charger for my laptop (if a laptop is even allowed) so I dont have to worry about that but if there aren't any outlets in the sleepers of Century, Columbia, and Classic Frieghtliners then I wont even be able to use it unless he is ok with wires running up to the front of the cab.
When I get my own truck you better believe an inverter is going in there, I 've used one for several years in my own car and have yet to set one on fire
Buying a small inverter for your laptop is far less expensive than buying a DC charger . I power my tv and laptop off an inverter and extension cord .
what size inverter do you need to power i small fridge , laptop
My cord cost about 45.00 for the new computer. Only to find out the DC cord from the old computer would have worked too.
The inverter was 20.00.
