Apus and inverters
Discussion in 'Questions From New Drivers' started by Nightwind8830, Sep 29, 2013.
  1. Nightwind8830
    Nightwind8830 Medium Load Member
    419
    192
    Jul 13, 2013
    Chicago,IL
    Just curious what is an APU and what is an inverter? what are they used for ?
  3. Emulsified
    Emulsified Road Train Member
    3,663
    3,499
    May 6, 2010
    Dallas, TX
    An APU is an Auxillary Power Unit. Basically a generator that produces enough electricity to run whatever you need. In most cases that's an airconditioner or things like a micro wave, or other electric appliances.
    An Inverter is a device that converts DC voltage to AC voltage and allows you to run some devices without an APU. Their power source are batteries, so their ability to provide power is limited to the extent of the storage in the batteries.
    They really work as a team...an inverter providing power for smaller use devices such as a light, small draw devices or things like TV's or refrigerators. An APu will produce larger amounts of power for higher use devices like microwaves and keep batteries recharged.
  4. Nightwind8830
    419
    192
    Jul 13, 2013
    Chicago,IL
    Do most trucks have either of these,and how do you know if a device can be powered by them?
  5. Chinatown
    Chinatown Road Train Member
    74,767
    170,266
    Aug 28, 2011
    Henderson, NV & Orient
    If you plan to do some serious long haul trucking, try to go with a company that has APU's.
  6. Uncle Ben
    Uncle Ben Bobtail Member
    45
    19
    Feb 1, 2013
    George West, TX
    When I drove OTR as a company driver for May Trucking, they had their own inverter policy. First, you had to buy the inverter from the company (2000 watt Tundra). Second, you must have the company shop install the inverter before you can use it. I guess they has some problems with drivers installing them and the trucks having electrical problems, fires and ect...
    Now the problem here is that the company also monitored your idle time and you were only allowed a certain percentage of idle time. Well you had to idle the truck to use your inverter. If you went over your idle time the company charged you for it! The one advantage was that you could finance your inverter and they took the payments out of your check every week. When I left the company I removed my inverter and I still have it.
    With an APU you don't have to idle your truck for them to work...
    http://www.tundrainternational.com/en/
    Uncle Ben
    Nightwind8830 and DoneYourWay Thank this.
  7. TruckDuo
    TruckDuo Road Train Member
    6,394
    9,373
    Oct 21, 2012
    Chicago, IL
    That sucks that May will make you pay for going over your idle limit.
    Asking about both is important when trying to pick a company.
    USX has no APUs but allows us to have an invertor up to 1700 watts. They install it for free.
    I've seen Gordon trucks with APUs.
  8. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    Both APU's and inverters give you power to run all your a/c needs like, microwave, fridge, etc. Inverter runs off batts or off engine power and thus has a limited run time when motor is off. You can't run a/c or heat off an inverter while the truck is off because the batts wont support it. An Apu can do the same thing, but needs to be running to provide power. It has it's own motor that charges the truck batts and provides power for everything. APU's have heating and cooling built in and can run without the truck engine on.
    Most companies will allow you to install their approved inverter or they provide one. Some have APU's but it much less common. For heating and A/c most drivers idle their truck witch provided heat/a/c and keeps their batts topped off. If using an inverter it is best to run the engine on the truck while using your microwave so the heavy draw doesn't kill your batts. if your batts are in good condition, you should be able to run a fridge tv and laptop for a 10 hours break off an inverter and still be able to start the truck.
    DoneYourWay and Nightwind8830 Thank this.
  9. Nightwind8830
    419
    192
    Jul 13, 2013
    Chicago,IL
    ah.... ill have to start asking recruiters about that. its something i didnt know to look into,actually.
  10. Uncle Ben
    45
    19
    Feb 1, 2013
    George West, TX
    Richter has a good point; even with a inverter installed in the truck you may still need to idle the truck to keep from draining the batteries down. If I was cooking dinner in my microwave then I would idle my truck, but for example if I was just watching a movie on my laptop then I would not need to idle.
    With an APU you can just start it and stop it as you need the power. I could be wrong but I think the TriPac APU's have a built in inverter (1700-1800 watts maybe). When the batteries get low while using the inverter, the APU will start up and charge the batteries back up.
    Also in cold climates most APU's can be connected to your engine cooling system and they keep the engine coolant warm to help in morning cold starts. Eliminates having to idle your truck in cold weather while your sitting at the truck stop for 3 days. :biggrin_25520:
  11. Richter
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    Most Apu's now have a separate cooling system to avoid your truck being dead if the apu cooling fails. Also the engine will over heat if you run both at once if they use the same cooling. most just have an extra outlet so you can runt he trucks block heater while the engine is off and APU on.
