APU thermoking keeps blowing F11 fuse condenser fan 25amp fuse
Discussion in 'Experienced Truckers' Advice' started by streetfloater, Apr 1, 2024.
  1. streetfloater
    streetfloater Bobtail Member
    Hello I am having issues with my apu not blowing cold air it will turn on for a couple of minutes then I get the orange triangle light then eventually the apu turns off. I realized the fan connected to my apu outside of my truck doesn’t turn on. And noticed the fuse corresponding with the fan which is the F11 fuse for the condenser fan (25amp) was blown. I replaced the fuse turned the unit off unplugged everything but that fuse again blew. Has anybody had this issue? Please help if you can, thanks
  3. Moosetek13
    Moosetek13 Road Train Member
    14,530
    18,015
    Nov 1, 2010
    Burnsville, MN
    Maybe the fan turns on but is frozen in place, so the fuse blows.
    Maybe replace the fan and see if that helps?
  4. RunningAces
    RunningAces Road Train Member
    1,263
    2,513
    Jul 2, 2017
    Check the cord, might have vibrated a hole into it and now it's blowing the fuse.
    shatteredsquare Thanks this.
  5. shatteredsquare
    shatteredsquare Road Train Member
    1,399
    1,825
    May 23, 2014
    middle dirt
    that fan pulls more to startup than 25 amp, put a 30 in and stay cool
  6. shatteredsquare
    1,399
    1,825
    May 23, 2014
    middle dirt
    I just replaced my condenser fan cause it was frozen stiff in like 15 degrees of travel, the other 345 degrees it would spin. motor housing was swelled up and cracked open like a leaky battery. went to change the fuse knowing it was blown too. it wasn't blown!? how tf not, idk. maybe not shorted, just buzzer mode
  7. shatteredsquare
    1,399
    1,825
    May 23, 2014
    middle dirt
    I swear to god there is probably a billion dollars of maintenance labor hours every year spent to rectify holes worn in little 12v wires in mystery places the sun don't shine that could be 100% mitigated by 50 cents worth of conduit and zip ties 5 years before hand
    RunningAces Thanks this.
  8. Alan080582
    Alan080582 Bobtail Member
    Dude how did you solve this problem I have exactly the same problem
