APU Question > Comfort-Pro APU - starts automatically every 5 min - truck engine is off
Discussion in 'Refrigerated Trucking Forum' started by JerryD13, May 15, 2022.
  1. JerryD13
    JerryD13 Light Load Member
    169
    126
    Oct 17, 2016
    APU Question > Comfort-Pro APU - so this Comfort-Pro APU -
    PROBLEM > APU starts automatically after the truck is Stopped ---- this happens hours after the truck has stopped and the motor is turned off.
    after turning on .. by itself --- I turn APU OFF -- then in 5 min, it STARTS AGAIN -
    can anyone tell me what is causing this?
    Thanks in Advance
    HERE IS THE FIX:
    > You got the APU programmed to keep the batteries topped off - when it hits below a set voltage.
    If it turns on immediately the voltage is set pretty high or the batteries are weak.
    Think it’s called the battery monitor.
  3. GYPSY65
    GYPSY65 Road Train Member
    1,956
    5,263
    Nov 16, 2012
    SW FLA
    You might have bad batteries and it’s calling for charge
    Also
    There’s a way to set the voltage or amps?
    down some to let it kick on later
  4. pumpkinishere
    pumpkinishere Heavy Load Member
    945
    4,984
    Apr 21, 2021
    Just curious where do you have your comfort pro serviced? We haven’t found anyone who works on comfort pros. Ours currently is not starting. It was leaking antifreeze so we turned the line off that runs to it but we need the system serviced. Nobody in our area works on comfort pro. I’m thinking we may have to take it to Ohio to get it worked on.
  5. Ffx95
    Ffx95 Road Train Member
    1,368
    2,628
    May 18, 2017
    You got the apu programmed to keep the batteries topped off when it hits below a set voltage. If it turns on immediately the voltage is set pretty high or the batteries are weak. Think it’s called the battery monitor.
  6. 062
    062 Road Train Member
    6,143
    33,182
    Oct 20, 2013
    Is it a carrier unit?
    If so, then carrier Nashville is a good shop.
    Carrier KERNERSVILLE N.C. is good, but slow.
  7. pumpkinishere
    945
    4,984
    Apr 21, 2021
    To be totally honest I’m not sure. I do know it’s a comfort pro and that’s about the extent of it. Lol
  8. JerryD13
    169
    126
    Oct 17, 2016
    HERE IS THE FIX:
  9. JerryD13
    169
    126
    Oct 17, 2016
    Comfort Pro is a top-of-the-line system made by Carrier
    heating & Air -- here is a youtube video on them.
  10. JerryD13
    169
    126
    Oct 17, 2016
    GYPSY >> you actually had the issue pegged - - here was the fix
    a set voltage.
    ** so on a 34-hour break, the batteries got LOW and the APU kicked in to top
    off the batteries at 1 am }
  11. pumpkinishere
    945
    4,984
    Apr 21, 2021
    Ty for the video
