approximate weight of this dump truck I won't keep doing this ----thanks
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by uhjohnson, Sep 30, 2014.
  1. uhjohnson
    uhjohnson Bobtail Member
    43
    Jun 13, 2014
    TRUCK TYPE TRI-AXLE DUMP YEAR 2011MAKE/MODEL KENWORTH T-800B MILES 181,359ENGINE TYPE ISM CUMMINS @ 385/410HP HOURSENGINE HISTORY JAKE BRAKE YESTRANSMISSION RTO-16908LL RATIO 3.91AXLE/FRONT 20,000# (D2000) GEARED SPEED AXLE/REAR 46,000# (D46-170HP) TRUCK WEIGHT G.V.W.R. 70,000# WHEELBASE 213"SUSPENSION HENDRICKSON HMX460 POWER STEERING YESC.A./C.T. 139" BRAKES S-CAMTIRES/FRONT 11R24.5 @ 50%+ TIRES'REAR 11R24.5 @ (6)80%(2)50%WHEELS/FRONT ALUMINUM BUDDS WHEELS/REAR STEEL BUDDSSLEEPER N/A- A/RIDE CAB INTERIOR SPLENDORFRAME DOUBLE STEEL A/C YESFUEL TANKS 1- 100 GALL ALUMINUM COLOR BLUE CAB/GREY BODYSERIAL# 1NKDX0EX6BJ277654 CONDITION GOODMISCELLANEOUS EQUIPMENT: W/ 17' PJ's/GODWIN STEEL DUMP BODY W/ 54"SIDES + BOARDS, 60" AIR-GATEW/ CHUTE, AR400 FLOOR, APRON, ELECTRIC TARP, 13,200# WATSON-CHALINSTEERABLE AIR-LIFT AXLE W/ 11R24.5 TIRES ON STEEL BUDDS,CHROME BUMPER, SINGLR STACK, VISOR, AM-FM CD STERREO
    I need the empty weight so I can figure how much I can haul up to 70,000 pounds in Maryland and no one is advertising the empty weight
  3. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,214
    Sep 23, 2007
    Statesville, NC
    Did you contact them and ask them?
  4. uhjohnson
    43
    Jun 13, 2014
    he says about 26,000 and some change but I am hoping someone here can get me closer because I don't want to go over 24,500-25,000
  5. Mark Kling
    10,935
    4,214
    Sep 23, 2007
    Statesville, NC
    might be hard to guesstamate just looking at it. If he is close then why not visit him and see if he can take you to a scale close around to weight it.
  6. jbatmick
    jbatmick Road Train Member
    2,195
    2,458
    Dec 1, 2009
    hastings, Fl
    You are wasting your time trying to guess a weight,nobbody can. The only thing to do is park in on a set of scales and weigh it. Do not trust a salesman to do it, he is trying to make a sale, and could possibly use a set of scales that were not accurate (?), and tell you a fib.
    postmandav Thanks this.
  7. Mattnatti
    Mattnatti Light Load Member
    239
    176
    Jul 10, 2014
    Cincinnati, Ohio
    Flotation tires on front would be the first thing I look at. They are so much better to drive than the " skinny " tires.
    I had 20.8T on my dump trailer today and weighed in 69,680lbs. I cannot imagine grossing 77k on a straight truck with one floater axel. Every once in a while......maybe, but all day every day....no way!
    The Kenworth looks to be spec'd with the Mack, axel wise. Typical size bed. This one is steel and the other was aluminum. Steel makes the truck more versatile but aluminum with a liner is the smack daddy for strictly aggregate.
  8. j_martell
    j_martell Light Load Member
    284
    184
    Jun 12, 2014
    Centre Wellington, Ontario
    stab in the dark.....13,000kg-15,000kg......just what I've come to notice.....
    you, my friend, need to have it scaled......
  9. Caterpillar Cowboy
    Caterpillar Cowboy Heavy Load Member
    837
    607
    Nov 11, 2010
    Wyoming
    If I was buying a truck, I'd call the salesman and tell him to get me the Tare Weight. If he wouldn't get it scaled to sell that truck at about $130,000 or so I would guess he could go number 1 into a strong headwind!
  10. Mean Streak
    Mean Streak Light Load Member
    56
    22
    Jul 30, 2013
    Boyd, TX
    call KW and maybe you can get an idea from the VIN?
  11. SL3406
    SL3406 Medium Load Member
    550
    1,482
    Jan 10, 2011
    Oklahoma
    I think it's going to be hard to find a truck that light that's properly rigged to gross 70k. I have a regular tandem single frame and 40k rears that weighs 23k. A double frame and heavy axles needed for what you want to do is going to add a lot of weight.
