App plates VS Standard plates?
Discussion in 'Ask An Owner Operator' started by 2hellandback, Feb 15, 2009.
  1. 2hellandback
    2hellandback Heavy Load Member
    978
    237
    Dec 19, 2007
    Blackfoot Idaho
    Apportioned plates vs standard plates:
    Whats are the advantages, and how do they work?
    Do they keep you from having to permit in every state you pass through when doing over the road hauls?
    Are there any other advantages using apportioned plates?
  3. Les2
    Les2 Road Train Member
    5,150
    2,288
    Jul 25, 2008
    kicked back in my lazyboy...
    You have to have apportioned plates to leave the state you are out of. I don't think you can buy a permit for other states without the app. plate.
    If you have no intentions of leaving Idaho just go with a State plate.
  4. pullingtrucker
    pullingtrucker Road Train Member
    1,185
    598
    Dec 21, 2008
    Fostoria, Ohio
    You are required by law to have commercial plates on a for hire vehicle and some private fleet trucks. I'm not sure but I think it depends on the GVW rating. The standard plates also won't be excepted for interstate commerce. They are meant for basically farm trucks that run locally. Apportioned plates have a set formula for the cost based on the estimated or actual mileages (which ever is higher of course) and the states you register for. Also included in this formula is a weight consideration. My Ohio base plates with 37 other states and a GVW of 80,000 lbs cost me about $1700 last years. I had to use almost all estimated miles because I just don't run many miles (I try to run less than 100,000 a year).
  5. Roadmedic
    Roadmedic Road Train Member
    18,951
    8,980
    Apr 4, 2007
    My pickup truck is commercial with regular plates on it at 26,000 lbs registration.
    Apportioned plates usually follow the IFTA rules of 26,001 lbs and up.
  6. 2hellandback
    978
    237
    Dec 19, 2007
    Blackfoot Idaho
    So any states im not register for, then i need to get a permit for that state prior or when i hit there port of entry?
  7. Roadmedic
    18,951
    8,980
    Apr 4, 2007
    You will need to check on the reciprocity between the state you are registered in and the state you are entering.
  8. 2hellandback
    978
    237
    Dec 19, 2007
    Blackfoot Idaho
    How is that done?
    i know the co im leased to paid $1900.00 for my apportioned plates in wyoming
  9. Roadmedic
    18,951
    8,980
    Apr 4, 2007
    Your company will know the states you need permits in.
    I have to buy permits in NM, AZ, ID, and check in at WY.
  10. PharmPhail
    PharmPhail Road Train Member
    3,084
    1,125
    Nov 7, 2008
    NC
    Is there a way I can find out in advance online what apportioned plates are going to cost me in NC?
  11. walleye
    walleye Road Train Member
    3,028
    4,306
    Aug 21, 2007
    Land of Cheese
    That all depends on which states you have on the plate,.....
