Hi, I'm a company driver. My co truck dose have a battery power ac/ heater for the sleeper. However after setting all night running the batteries are depleted. It takes 6-8 hours of drive time to fully recharge them. This works fine when I've run all day. But sometimes I get stuck at a dock for hours to be loaded, and my batteries quickly run down. My truck will not stay idle for more than a few minutes unless it is below 10F so I'm thinking about one of those little portable propane heathers folks use for camping.
Anyone using a portable propane heater?
Discussion in 'Experienced Truckers' Advice' started by tnscavenger, Nov 27, 2013.
Page 1 of 6
Fmcsa 393.77 under heaters....types prohibited under (a)(6)
Portable heaters shall not be used in any space occupied by persons except the cargo space of motor vehicles which are being loaded or unloaded.
Tried to to post the link but couldn't get it to work in my phone lol the way I read it it isn't legal but somebody more familiar with that particular reg may elaborate on it more
not telling you what to do by any means as I looked into it myself when I was job hunting because I WILL stay comfortable lol I just got lucky and got a good gig that provides trucks with outstanding bunk heaters.Last edited: Nov 27, 2013
Set your cruise control and manually increase RPMs with the button to like 800 or so.
alds, free spirited1, DsquareD and 3 others Thank this.
roshea, DoneYourWay, bigjoel and 3 others Thank this.
The night the APU died, I woke up at 4 in the morning and it was 19 in the sleeper and minus 26 outside. The truck started, but every 4 minutes I had to restart it.blairandgretchen Thanks this. -
DoneYourWay and blairandgretchen Thank this.
I started it and bumped the cruise. It shut down as usual.
I started it and pulled out only the trailer brake, it shutdown as usual.
I started it and no brakes pulled and it shut down as usual.
I started it and no brakes ran the rpms to 1500 and it shut down as usual.
I started it and put the automatic in gear and held the brake and it shut down.
Called night dispatch to tell them.
He said, what do you want me to do about it. Did not care at all. The next 3 hours were miserable.alds, free spirited1, DoneYourWay and 1 other person Thank this. -
DoneYourWay, Roadmedic, Grumppy and 3 others Thank this.
No way would I run any type of portable heater in a closed environment and risk Carbon Monoxide death. Our bunk heaters work great. Right now I haven't had to use mine but I run a 300W inverter for my cpap, my fridge and sometimes a fan all night with no problem. I do have 4 new batteries and if you treat them well they will be o.k.
Our trucks have a low battery alarm that sounds and lets you know to turn on the truck and run the batteries up. We also have free idle at under 20 degrees and over 80 degrees. On our Volvos you can defeat the auto shut down by cruise or tapping the break, but you risk going over allowed maximum, but they are pretty generous with the amounts allowed.Skunk_Truck_2590 and blairandgretchen Thank this.
Page 1 of 6
