Anyone use live bottom trailers? for Gravel or Asphalt?
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by MrFred, Jan 18, 2015.
  1. MrFred
    MrFred Bobtail Member
    40
    13
    Sep 10, 2011
    Williston , N.D
  3. Singh181
    Singh181 Light Load Member
    57
    43
    Jan 26, 2014
    San Jose, Ca
    Never heard of live bottoms used for gravel or ac work. Mostly always bottom dumps or end dumps. If its a really tight space then transfers or superdumps or super 10s. The trailer in that link looks more like a framed end dump to me but i could be wrong.
  4. 201
    201 Road Train Member
    12,044
    24,581
    Apr 16, 2014
    high plains colorado
    I could see them being used for gravel, like your picture shows, but asphalt would pose a bigger problem, as the trailer couldn't be used for much else, as a lot of asphalt would stick to the sides or the conveyor system. Without fuel oil, which used to be used to facilitate clean removal of the asphalt, but now is a huge EPA no-no, I think it would clog up the conveyor. Probably not the best idea.
  5. special-k
    special-k Road Train Member
    1,523
    3,258
    Dec 27, 2008
    Southern Ontario Canada
    They use them for both all the time in my area. They are usually a v bottom with a belt around 48" wide.
  6. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    iv seen that type of trailer used for hot mix, never seen one hauling gravel though. when i think of using something like that for hot mix seems like it would be a mess. they also seem to be the worst for blowing you your windshields. when i see belt trailers like that hauling asphalt i always try to keep my distance.
  7. 201
    12,044
    24,581
    Apr 16, 2014
    Hi special-k, I could see them being used for asphalt and gravel, but I don't think you could haul potatoes or grain after asphalt.
  8. MrFred
    40
    13
    Sep 10, 2011
    Williston , N.D
  9. White Dog
    White Dog Road Train Member
    3,161
    3,807
    Feb 11, 2008
    Iowa
    Manatt's in my area use them almost exclusively: http://www.manatts.com/ They been around a long time.
    At first I thought you meant "walking floor" like I've seen used in waste disposal. Those are pretty cool.
  10. poppapump1332
    poppapump1332 Road Train Member
    2,987
    2,465
    Jan 2, 2010
    birdsboro,pa
    Indian valley carriers has one they use for sand,stone,salt i never pulled one so i dont know the advantage over a end dump except maybe where there is a height problem.
  11. White Dog
    3,161
    3,807
    Feb 11, 2008
    Iowa
    The advantage is, you don't have to drive over the load, and can lay it in a row like a belly dump to make it easier for the maintainer/grader to spread evenly on a surveyed grade.
    "semi" retired Thanks this.
