Anyone use Arctic Fox fuel tank heater with TK Evolution?
Discussion in 'Ask An Owner Operator' started by Midwest Trucker, Feb 11, 2021.
  1. Midwest Trucker
    5,871
    21,124
    Aug 31, 2018
    My truck has Arctic Fox fuel tank heaters that sense when the fuel is too cold and then bypasses warm coolant until the diesel is at optimal operating temperature. This works great as long as the truck is running. Combined with a winter grill and the Fuel filter heater it takes most all the worry out of ever gel’ing up.
    Currently, the truck has a diesel fired bunk heater (Espar) but no APU. With fuel being cheap I didn’t see the ROI. However, I anticipate fuel rising in price significantly over the next years so I’m starting to take a look at possibly adding the Thermo King Evolution with the arctic package in the future.
    My question mostly consists of, does anyone run this setup together? I’m very interested in the fact that it could be zero degrees or below and the truck sit over the weekend and have no problems at all. The engine would be warm, the fuel would be warm, and the batteries would be charged.
    I’m looking to this as a three fold solution. 1. Driver comfort and retention 2. Fuel savings 3. Decrease my worry that we’ll have a problem while the truck sits over the weekend in zero degree weather. Technically, we would never even have to treat fuel, as we only do now for the weekends when it’s very cold and engine off.
    Any thoughts or opinions welcome. This is not an area of expertise for me by any means! Thanks.
  3. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    so no talk for the batteries. all the above are good. but i would still use anti gel my self. if zero degrees. i would double up on anti gel. but the truck mite not crank. if batteries get low
    GYPSY65 Thanks this.
  4. Lockport
    Lockport Light Load Member
    170
    112
    Mar 26, 2011
    Lockport, MB, CAN
    The Arctic Fox 703-BTEH inline fuel heater has a block heater like plug capability with a pre-installed 70 watt heater (you have to buy the plug) and installs within 24" of the first filter. You can daisy chain from it to your in tank elements and it also has the warmer temp shutoff valve on it. I had a truck that I would plug in it, the block heater, I also had a 110w oil pan heater and the inverter which had a trickle charge battery capability. Saves you nearly $15k on the Tripac.
    If you went with the Tripac, Arctic Fox makes an intake element with a spiral draw tube around the outside of the coolant pipe that is designed to feed an APU.
    I never had a failed start with mine no matter how cold. No guarantee that your Espar doesn't gel in that config though. I find the D4 Espar is much more dependable than the D2
    Rideandrepair and Midwest Trucker Thank this.
  5. 062
    062 Road Train Member
    6,141
    33,149
    Oct 20, 2013
    I have a 1st gen tripac and I think you’ll be disappointed with the expectations of keeping the motor warm. I have the water temp sensors and it will kick on around 32* but it doesn’t run long enough to put much heat in the motor. You’ll probably see a 10* rise if there’s not much wind.
    Maybe @reeferwrencher knows if the evolution does better or can have parameters changed for longer run time.
  6. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    Isn’t there a super arctic package that has the block heater only 600W and a oil pan heater too......?
    According to the new generation fuel never gels and all those things are a waste of time/money.....
    But I’m with you ....... -20F and more separates the weak trucks out pretty quickly.......
  7. reeferwrencher
    reeferwrencher Medium Load Member
    556
    1,474
    Aug 4, 2018
    The evolution from what I hear is better than first gen tripac,which as mentioned above weren't very good.The thing to remember with tripac is that it s not a factory install.Even though the unit is brand new the quality of installation can make all the difference.I saw so many failures in them when I worked at tk that I have a hard time being positive about anything that isn't a factory install.Just my thoughts on apu
  8. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    oil pan heater works great
  9. Ridgeline
    22,098
    113,137
    Yes I have a few trucks with the same apu and the artic fox in tank heater. It works well.
    for example I had to move a truck this morning, 7 degrees out, it sat for a week. Batteries are charged and it has a maxwell starting module. I didn’t plug it in, it is too far from the building to do that. So I got into it, cranked up the apu and let it go for 45 minutes, went into the office than back out and it started right up, no issues starting and it was nice and warm.
    I had one issue with artic fox heaters a while back, I got two of them which were cracked at the bends, they promptly replaced them.
    cke, Rideandrepair and Midwest Trucker Thank this.
  10. GYPSY65
    GYPSY65 Road Train Member
    1,956
    5,263
    Nov 16, 2012
    SW FLA
    I just switched from the D2 to the D4 in my new truck, a Peterbilt Ultraloft and that heater will have you sleeping naked
  11. Midwest Trucker
    5,871
    21,124
    Aug 31, 2018
    Thank you! Exact kinda feedback I was hoping for. You are going even more above and beyond with the Maxwell battery. That is food for thought as well. I’d like to think this overall combination should in theory be completely trouble free no matter the weather.
    cke Thanks this.
