i am replacing all 8 drives soon. i have run Michelin and have continentals now iv had pretty bad luck out of the continentals broken belts on 3 of the drives now with only 142k on them iv had my steers pro rated twice with the same problem. Im running all highway hauling a reefer i have never had that problem before got almost 260k out of my last set of tires.. im thinking about switching to toyo drives particularly the m657 any one running those and having any luck out of them im also open to suggestions im running 11R22.5's
Anyone running toyo drives
Discussion in 'Ask An Owner Operator' started by rtyauch301, Nov 12, 2016.
I put 8 M657s on in June. So far they are good, no noticeable loss in fuel economy, ride and handle just fine. They replaced 8 M647 that are discontinued.
Good tire imo -
I can't speak for Toyo's cause I've never had experience with them but a good alternative to Michelins are Goodyear or Bridgestone. They are front runners when it comes to wear in my eyes. Michelins are a great all around tire though. Other alternatives you could maybe check out are before Toyo's are Yokohama, BFGoodrich or Hankook tires. Just a thought.
I just pulled off two Toyo steers that were 18 and 24 oz out of round in less than 70,000 miles.
Running Michelins, now.
I do run Toyo 157's on the trailer, and they are doing well, there.Hurst Thanks this. -
My best set of drives were actually some el cheapo Hankook DL07 tires. I only experimented with the Toyo and Continental to see if paying more actually resulted in longer lasting tires. The Hankook DL07 lasted for just over 400k mi. And only reason I pulled them was because they were starting to get greasy and slippery on wet roads. They still had roughly 30% tread. I'm going to go back to them and hopefully I get the same results.
Hurst -
1st pair I ran at 100psi and they started cupping and wearing hard on the inside edges. I got about 125k mi out of them before the shaking became too much. I went back and was going to try some different steers. Dealer told me I should have been running them at 110 PSI and to make sure I did had a good alignment. My alignment was over a yr old when I put the first pair on. He said they were the best steers on the market. I was a little angry at how they ended up. But decided to give them another try. Tires mounted and balanced, 3 axle alignment. Religiously maintained 110 PSI and made it to 240k with excellent wear. I wasnt ready to replace them yet,.. but I had pulled over on the shoulder of an off ramp one night to pee and ran over some kind of sign post. Had no choice but to replace both of them.
They say picture is worth 1000 words,.. I had some choice words when this happened.
2CAN Thanks this. -
Hurst and gerardo1961 Thank this.
For my columbia 07 the michelin is the best on steer
I try yoko.bridgestone.without thinking michelin.more miles and i buy from nationalaccont -
It is being replaced by the Michelin X® Line™ Energy Z.
I've had good luck with both the Michelin XZA3+ and the Bridgestone R283 Ecopia Steer tires.Last edited: Nov 14, 2016
2CAN Thanks this. -
Anyone have experience withand Bridgestone R283a and how do you like them?
Since company put these on my truck wanders all over the road. Previously had Michelins on there.
