Anyone run a Winch truck or know anything about them
Discussion in 'Oilfield Trucking Forum' started by FlyingJ mafia, Aug 1, 2023.
  1. FlyingJ mafia
    FlyingJ mafia Bobtail Member
    21
    6
    Apr 10, 2021
    Hi,
    I found a decent truck that has a winch on the back. Can you also haul sand boxes and what ever else you want with that kind of truck? Would you also be able to put a wet line on the back next to the winch?
    I am curious If this can be done.
    Thanks
  3. MacLean
    MacLean Road Train Member
    1,266
    3,712
    Sep 12, 2017
    You could also haul sand but that winch truck (guessing it’s a Western Star) will be pretty #### heavy.
  4. FlyingJ mafia
    21
    6
    Apr 10, 2021
    Its a CAT truck, Like or hate them
    • GVWR: 60,320 lbs
      • FAWR: 14,320 lbs
      • IAWR: 23,000 lbs
      • RAWR: 23,000 lbs
    • Probably would be over weight pretty fast.
  5. JoeyJunk
    JoeyJunk Road Train Member
    8,763
    68,024
    Dec 31, 2010
    Washington, PA
    Those cat trucks were garbage. And sand hauling currently is garbage. Overtrucked and underpaid. The glory days of lucrative sand hauling are gone. I only do it because I live close to the action.
  6. MacLean
    1,266
    3,712
    Sep 12, 2017
    Only thing I know about the Cat (Sterling) trucks was, and I was told this, that they have crap front ends / front axle and they’re heavy. They’re made to be dump trucks.
  7. FLHT
    FLHT Road Train Member
    1,329
    2,261
    Aug 2, 2014
    Local Cat dealer her has their 3 parked .
  8. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    Run away…..
    lester Thanks this.
  9. AModelCat
    154,271
    I wouldn't touch a Cat truck with a 40 foot pole. Just a rebadged International with next to zero dealer support. Most Cat dealers won't touch them, the one I worked at didn't.
  10. RockinChair
    RockinChair Road Train Member
    4,919
    12,257
    Feb 19, 2012
    CC, TX
    If it has a hydraulic winch (which is the kind that most winch trucks have) then there would be no need to add a wet kit, because it already has one.
    But I'm not sure why you would want to add a wet kit for sand hauling.
  11. RockinChair
    4,919
    12,257
    Feb 19, 2012
    CC, TX
    Even if it was a gin pole on the back of a Western Star?
    Bean Jr. and JoeyJunk Thank this.
