Anyone run a landoll?
Discussion in 'Ask An Owner Operator' started by Dino soar, Feb 22, 2025.
  1. Dino soar
    Dino soar Road Train Member
    4,789
    26,858
    Dec 8, 2017
    In my area it's very easy to keep a tri-axle dump truck busy in the summertime.
    I was wondering if it's the same or similar with a landoll.
    I was looking to buy a tri-axle dump truck, but I've come to realize that I could use a landoll for a lot of different things for myself.
    It seems like I'm always moving stuff and it seems like there's plenty of disabled stuff and the more I've thought about it, I could really use a trailer like that for myself.
    So if I could work the trailer while I move my own things and all of that, that would work for me.
    So just generally speaking, if you're not far from an urban area, is it difficult to keep a landoll working everyday in the summer?
    Where else can you put a trailer like that to work aside from the rental companies and maybe some contractors moving equipment?
    Reason for edit: I changed the post because I realized I need a landlord trailer rather than a tandem rollback.
  3. Ridgeline
    22,112
    113,286
    A friend down the road from my Indiana yard has a few; I know one of them has a 30k capacity. It is a KW, I think 660, it is a Century bed on the back of it. We have used it for a customer who had to move a 25k die set and locomotive engine.
    He does a lot of recovery-type work with it, he also has a rotator or two that is used for towing tractors.
    He is busy most of the winter.
  4. Dino soar
    4,789
    26,858
    Dec 8, 2017
    That type of business of landolls and towing...
    It's like a lateral step from freight trucking and dump trucking I suppose, but when you get in your groove it seems like you can do pretty well.
    Bumper and Albertaflatbed Thank this.
  5. Dino soar
    4,789
    26,858
    Dec 8, 2017
    And now that I brought up landolls, is there a benefit to having a Landoll versus a rollback truck?
    I would think the landoll would be able to move bigger heavier things, but the cost is similar between buying a trailer or buying a whole rollback truck.
    Is there anything that you can do with a rollback truck that you can't do with a landoll?
    As I write this it seems like if they can do the same job and be hired out at the same place as the landoll, seems like it would make more sense to just buy the trailer.
    It probably has a broader list of work that it could do and I could pull it with my tractor instead of running a whole separate truck.
    Am I missing anything in my thinking here?
    I think I need some advice on this thread too, Brian.
    @brian991219
    Bumper Thanks this.
  6. AModelCat
    154,488
    From memory the most common telehandler sizes we rented (10k and 12k) were too heavy for a tandem rollback to haul. The company we used for delivery were pushing close to max gross weight on their tridrive rolloff when they hauled them with it.
    Some of the straight boom man lifts were too long to fit on the deck of a rolloff as well.
    Bumper Thanks this.
  7. brian991219
    brian991219 Road Train Member
    2,924
    5,816
    Aug 10, 2013
    Lords Valley, PA
    They both have their place. The tandem industrial carrier (rollback) is great for rental lifts and similar equipment going into tight areas but is somewhat limited due to the vertical clearance. A rollback is usually 4' deck height where a Landoll is 32-36" deck height depending on model. Rollbacks are great for forklifts.
    The Landoll, or any other brand of sliding axle trailer, is very versatile which is why so many towing companies have them. If I had to choose only one I would pick the trailer 9 out of 10 times.
    Now, as for keeping them busy, it is possible if you are a good salesman. For the local work you are describing you will need to pound on doors and build relationships, the work isn't going to come from loadboards or brokers, at least not local work worth anything. The towing companies pretty much have the big houses like Hertz, United and Sunbelt locked in for overflow work but there are still plenty of others that would gladly build that personal relationship.
    The other nice part about a Landoll is that it is a trailer, so when the season changes, you park it and hook to a different trailer. I always have said, trailers are cheap to own and park when not needed. Whereas the industrial rollback, well it is expensive to sit when not needed.
    Bumper, W923, Dino soar and 1 other person Thank this.
  8. 50WT
    50WT Road Train Member
    2,034
    17,520
    Dec 26, 2015
    Landoll is very versatile trailer, most rental companies around here have gone to a folding tail , trail king seems to be the better of them. The rental companies are good customers,some pay 60 days out , but the money is dependable. They will have a variety of different demands for insurance, United is the most expensive to get set up with because of the insurance requirements. If you're in a area with multiple rental places you may find smaller local companies easier to deal with. The bigger the company the more you really need to watch the paperwork , cross it's and dot i's. If you do buy a Landoll or folding tail I'd recommend one with a good winch and a all way remote control. Those 2 things are a life saver for a one man loading dead equipment kinda thing. Also check with local wrecker companies, if they don't have a Landoll there could be times they would use you.
  9. Albertaflatbed
    Albertaflatbed Medium Load Member
    333
    877
    Nov 20, 2022
    Nisku, AB
    I run a landoll type trailer with my current employer when they need something moved.
    When I had my own company we had one as well. We had contracts with Hertz and sunbelt rentals. Also with construction companies to move vehicles and equipment from site to site, did some recovery work, but the big payday was the underground mineing equipment we moved .
    Think Procon, Cementation as a couple companies. This did require running good i to the mines to deliver so hard on equipm5bit we charged accordingly.
    Bumper and Dino soar Thank this.
  10. abyliks
    abyliks Road Train Member
    3,747
    8,695
    May 2, 2010
    ludlow MA
    My uncle had one for a while, too tall to do much of anything with it and sat in the yard while the low bed strayed hooked
    Bumper, Dino soar and Albertaflatbed Thank this.
  11. Albertaflatbed
    333
    877
    Nov 20, 2022
    Nisku, AB
    Yeah, depending on what you move regularly, the lowboy and a landoll style trailer are really for two different types of work.
