Anyone own an International with Auto Shift???
Discussion in 'Ask An Owner Operator' started by JD Transport, Mar 25, 2015.
  1. JD Transport
    JD Transport Light Load Member
    53
    17
    Sep 24, 2014
    Hi, I am looking at purchasing an 07 International, Cummins ISX 450, with autoshift. Been driving 10 speeds and only drove one automatic, which was a 3 pedal Volvo. I know alot of people dont like the thought of auto in a semi but it sounds like a nice feature, I just dont want to have breakdowns and unnecessary bs. I want it to be reliable.
  3. jnl_430
    jnl_430 Bobtail Member
    I've had one for a year and a half and love it. have never had any problems with it but it would be good for you to read the manual on it -- it was very helpfull
  4. boneebone
    boneebone Road Train Member
    2,294
    2,365
    Mar 13, 2009
    If you want your truck to be reliable, stay away from Automatics, sure it's nice when they work, but when they start acting up, you'll be throwing money at it left and right. I would stay with a Manual Transmission.
    MZdanowicz Thanks this.
  5. d60-14
    d60-14 Light Load Member
    72
    30
    May 23, 2012
    What is the mileage on the truck? The 3 pedal auto shift is the better option vs Ultra shift. They can be converted to manual and are reliable. There are a few things you have to do to keep them running.
    Check the oil level every time you grease the truck. If the oil is too dark, change it (the right oil is full synthetic SAE 50). The x-y electric shifter lasts about 400-500 000 miles, if your's is close to that - replace it! Cost $770 + Tax and 5-6 hours of your time, access is from the floor, no need to take down transmission, to get to this cover you have to remove seats. The other thing is the harness - $197. TCU is $1500, but is good most of the time. If you afraid to do it yourself, Do not go to the Dealer for this job, because they will replace all 3 - no matter what part is bad, just to charge you more money ~ $4000. Find a reputable transmission shop that have experience with auto shift. The easiest way to do it is when your transmission is down, because if the transmission is on, for the harness and TCU, you may need to remove driver's side fuel tank.
    If you change the x-y shifter and harness and the oil is clean, the transmission will run another 400-500 000 miles without any problems. There are a few more sensors, that are easy to replace, go to EATON-Fuller and download the Troubleshooting manual and read.
    Volvo I-shift and Meritor Freedom Line are using air cylinders to shift gears and depend on the air pressure, if the pressure is not hi enough - transmission can't shift. Parts are far more expensive.
  6. JD Transport
    53
    17
    Sep 24, 2014
    this truck is super clean, has the 2 pedal auto, which is ultra shift i believe? 845k miles. Hoping it can make me some money before anything significant needs fixin. I havent made up my mind just yet but this is the nicest one i've seen. I've been driving beat up company trucks (10 speeds), Volvo's & FL's so i guess its not too hard to impress me with a nice, newer, shiney truck....
  7. d60-14
    72
    30
    May 23, 2012
    The better model of the two Ultrashifts is Ultrashift Plus, this one has a regular clutch - powered by electric motor, the motor is where the fork is placed on a standart transmission. The bad one has a centrifugal clutch wich is POS - Ultrashift - No Plus! Go under the truck and check the tag on the transmission, take photo and then Google the model. The tag is close to the tail, normally on passenger side.
  8. ljmenez1
    ljmenez1 Light Load Member
    73
    4
    Dec 30, 2014
    los angeles ca
    I have a kw with the ultra shift it runs really good it has almost 800k trany shifts great and believe me its much better than shifting, it does take a few days to ajust to driving auto, but at the end its worth it. Good luck
  9. Medz
    Medz Bobtail Member
    13
    Northridge, CA
    Never owned one but had one for penske for almost 6 months. Transmission ended up needing major work twice during that 6 month period. I got to agree with boneebone. You want something reliable, avoid the automatic transmission, and definitely avoid the international. They go for a lot cheaper than the rest for a reason.
  10. OONewbie
    OONewbie Light Load Member
    245
    134
    Dec 2, 2014
    Charlotte,NC
  11. jdiesel3406
    jdiesel3406 Light Load Member
    276
    175
    Apr 28, 2013
    Philly area
