anyone know what these codes we got off a computer mean. blower motor protection mode. mechanical system not responding properly.( i changed motor thinking thats why it was on such low speed and it didnt work)
key switch battery potential- voltage below normal or shorted low- cascadoa hvac front and rear. ( i think its why my truck takes a minute to start. i need like 5-7 reset with key to get it to start
anyone know what these codes mean 2012 cascadia
Discussion in 'Freightliner Forum' started by 4noReason, Aug 27, 2018.
4noReason Thanks this.
Do the simple things first check ur batteries. You have to unhook them and test individually. Sounds like you got a bad starter or ignition switch. You can test the starter turning the key on and touch the 2 post on cylinoid with a screwdriver or jumper wire. If it’s in the switch or solenoid it will start. If it won’t start it ur starter or batteries. Their are 2 fuses in the fuse box. A 30amp and a 5amp sitting together. On a freightliner they sit bottom left corner usually hidden. One of those control ur blower motor. I put a 40amp and 20 amp in mine works fine now. I don’t know why anyone would use a 5 amp fuse but that’s wat will be in there
4noReason Thanks this. -
